another
TDaniel
>This one is 12.5" diameter x 8.5" high with a base diameter of 4.5". By the formula the height is 2/3 the diameter and the base is approximately 1/3 the diameter. The finish is lacquer. Color is layered dyes.
another
TDaniel
Re: another
Ken Grunke from SW WI
>My artist's eye would have preferred seeing the curve continuing around to a much smaller bottom, just a flat or slightly concave one.
But I'm sure the buying public wouldn't be so finicky.
You are correct
TDaniel
>I saw it as soon as I stood it up but it was too late. Just a little off the bottom corners would be nice but then I could never match the colors again. I may try though....maybe just try to contrast the colors. As someone said earlier, just an eighth of inch sometimes is the difference between good and almost good.
