Dental Light Pics
Dental Light Pics
Dental Light Pics
Bill Grumbine (Kutztown PA)
>Hello again everyone
If I had spent a little more time studying the light, I probably would not have even posted the question. I spent about as much time modifying it as I did typing my post - well, maybe a little more time, but not above 15 minutes. Here are some pictures of the almost finished work I need to plumb the thing up and put a plug on the end of the wires and I am in business!
Here is the light in its entirety. It sort of looks like something out of War of the Worlds, at least the original movie. The vertical post coming out of the large bracket screwed to the beam is the part I had been asking about. The whole light hangs from it.
Here is a shot with the light extended out of the way and into its working position. The metal plate is bolted to the beam and then the large bracket with the bolts is used for making it plumb. The light itself has a fairly large range of motion, but it does have some restrictions, so I am going to have to fiddle with it and the position of the lathe for optimum lighting.
Finally, here it is in its position over the lathe. I want to be able to illuminate both the headstock and tailstock sides of a piece, so there is where the fiddling around is going to come in. I can tell you right now, it is going to be easier to move the lathe, and maybe even the dust collection tube than it will be that light. Not only is it ungainly when it is flopping around loose, it is held into a 63 year old red oak beam with 3 1/2" lag bolts (all I had on hand).
Thanks to everyone who responded. I have two Moffat lights which will stay with the Poolewood, but this addition should make working on the Vega even nicer.
Bill
Re: Dental Light Pics
Gerry Meekins
>Cool Bill,
I've got a molar that's been bothering me. Maybe you can have a look at it when I come up for the picnic. LOL
Gerry
P.S. Now thats a Light!
No Fair!
Dominic Greco in Richboro PA
>Bill,
You been moving tools around in the shop again, haven't you?
I just got used to the old layout and now you hand me this bombshell. How will I ever hope to adjust? :>)
Really now, that dentist's light looks like it will really work out great. Can't wait to see it in action.
Later,
Dominic
Rick Davenport
>Why does the movie Little Shop of Horrors keep popping up in my head?
Rick
Dave Peebles Lyons, Ohio!
>Hi Bill.
That looks great! I sure do love mine. I posted a link for a source for bulbs in the other thread. I am sure you are going to love it. It throws a really nice pure light that lets these old eyes see all those nasty sanding scratches that someone put there after the piece was done. :)
Dave
Jim Swank
>You can make the light movable along the beam for some more trouble if you wish. Attach a lightweight I-beam to the bottom of your oak beam, flange bolted to the oak. Then make a metal plate to attach the light to and attach it to the I-beam with a pair of pipe hanger clamps. We called the clamps Caddy clamps in my electrician days. They're basically a C-clamp type cast body with a setscrew in the top that bites into the top edge of the flange and a threaded hole on the bottom that your plate and light would bolt to.
Once done, a minute with the wrench would let you slide the light anywhere along the I-beam. Whether the flexibility is worth the trouble of setting it up is a question only you can answer.
tek-Brunswick, Ohio
>Bill taking a molar out with a 1/2" bowl gouge, now taht's a scary thought!
Just keep asking, "Is it safe?"
Craig Daymon
>Hopefully, we won't hear you uttering those words from the barn during your picnic. Otherwise, someone better bring a BIG bottle of oil of cloves.
-Craig
(Obscure movie reference brought to you from "Marathon Man".)
