blue wood?
blue wood?
blue wood?
Leppikallio
>Is there some wood which is naturally blue and stays blue even over time?
Re: blue wood?
maybe, sorta
TDaniel
>The only wood that I know of that can be a very pretty blue is poplar. I think the minerals where the tree grows has a lot to do with the color so finding blue poplar is rare. Keeping the blue is another matter. I have kept it a while by coating it with Krylon UV block. Keeping it out of a sunlit area helps too.
Re: blue wood?
Re: blue wood?
Scott Greaves in Blackfoot Idaho
>I have done some work with what we call "blue pine", which is not a variety of pine, but rather it is pine that has a natural staining from insect infestation, and it turns the wood pretty blue, but not all the way, just in areas. So if you're using it for a big project, it probably wouldn't work, but for small projects it might.
Scott.
Re: blue wood?
Re: I see it all the time!! Thankfully..
JamieDonaldson
>.. it is mostly the result of uninformed wood photographers who haven't realized the effect of blue backgrounds or shooting photos with shade for a light source! And fortunately it is not permanent!
Re: blue wood?
But...
Barbara Gill, Remlik VA
>Blue stained wood gets greyer over time especially with an oil finish.
Re: blue wood?
Blue spore?
>Around here we have something called blue spore, wood can look really blue, specially white pine.
Re: blue wood?
Re: blue wood?
Jose Klipstein
>Hibiscus elatus aka blue mahoe. Not sure if or how long it retains its blue color.
Re: blue wood?
Leppikallio
>Carpe diem...! ;-))
Maybe I should turn the item from holly and buy blue glasses to her with the item?
Re: blue wood?
Re: blue wood?
OB O'Brien
>There is a furniture maker here in Pensacola, Fl that buys wood from Italy and it's pressure dyed a pretty blue through and through. If your interested in more info, let me know and I'll get it for you.
Re: blue wood?
Re: blue wood?
Charles Bjorgen
>I've turned some pieces of spalted buckeye burl in which the spalted areas of the wood were definitely blue and have retained that color over the past couple years.
Re: blue wood?
Re: blue wood?
Rick Davenport
>I believe blue wood comes from sad trees!
Ricki
Re: blue wood?
Re: blue wood?
eaglesc
>I couldn't find any so I made my own
