Twice turned bowls
Twice turned bowls
Twice turned bowls
RP Edington
>I just got my Easy-Core. It works well. I had several walnut logs that I wanted to make nested bowl sets from.
The coring went well. I put them in bags and weighed them in grams. As the weight loss slowed or stopped I decided to turn a set of them.
I mounted the bowl on the 3520a and realized I was going to have to turn these bowls backwards from my normal method.
I usually use a faceplate and turn the outside to final with a fixing, reverse and hollow out and sand to final, reverse on a longworth chuck and cut off the fixing and final the bottom.
Well, now I can't hardly turn the outside from left to right (from the base to the rim) with the bowl in the chuck on these cored bowls. I act like I've never had a lathe tool in my hand before. It is like riding a bicycle with your arms crossed! It is okay until you have to make a turn!
Is this something I'm gonna have work through? Or am I doing something wrong?
RP
Re: Twice turned bowls
>RP I don't have a coring machine but have turned a lot of dried rough outs. I mount them between centers using a block in my chuck that has leather on the tip. The tailstock has a cup center. I can true up the tenon and then turn the outside. This way if the bowl warps unevenly you can still adjust the centers a little to compensate and hopefully not lose a good bowl. That's my way at least, your mileage may vary.
A glue block sounds like a good idea
GaryG in MD
John Leonard
>I use much the same way as John except when I put between centers I use the chuck as a friction drive, the inside is going to be turned again so it doesn't matter if it get scuffed a bit. I do use John's method to turn off the bottom. John L.
George Van
>I do the same as John.
>I should mention that I often use the chuck as a drive also. I just put a rubber sink stopper over it. I will use this to reverse turn the bottom when I'm finished also.
Brian McKearney
Brian McKearney
>You might try to pick up a copy of Bill Grumbine's DVD on bowl turning. It helped me a lot and he actually discusses turning the bowl in the same orientation as you describe. He discusses turning both left and right handed, and shows some techniques that I didn't know prior to watching the video to get better cuts.
I always turned the bottoms of my bowls facing the tailstock, but now that I core I tend to true up my tenon and then mount the roughed bowl in the chuck and turn both the outside and inside without removing from the chuck. It took some practice, but this is the method that I now use for all of my bowls.
Brian
robo hippy
>Well, I don't return mine, which means a different coring approach. I remove the biggest core first. Most of the time on bowls up to 14 to 16 inches I drill a hole, using a forstner bit so that I can use the chuck instead of a face plate to mount the bowl to turn the outside. I reverse, then core. I then finish turning the biggest core. Next I remount the core, turn the bottom, reverse, then core again. I never have to take the chuck off. If I do use a face plate, before removing the first core, I will cut a mortice for remounting the core.
robo hippy
Brad Vietje
What He Said...
Brad Vietje
>This usually works perfectly.
If you want a little more support near the rim of the bowl, make up a few disks of whatever scrap you have on hand so they will fit whatever jaws you'll be using, and use these to drive the bowl opening. I have a few in the 6" - 10" range that fit my #2 and #3 jaws, and use 'em all the time. You can also use chunks that never quite became a bowl, due to checks, or whatever, and drive a bowl with a bowl, (inside or outside).
Worried that the rough-out is oval, and the scrap piece (now its a chuck) is round ? No worries -- you'll have 3 solid points of contact -- two inside the bowl, and your live center makes the third. Remember, you can chuck, re-chuck, reverse, and re-mount the bowl as many times as needed to get the desired result...
Safe spinning,
Brad Vietje
Newbury, VT
