Bealle/Axminster Collet Chucks
Jeremy in LA
>Hi there! Does anyone have experience with either of these two chucks?? Any information, opinions, or second-hand knowldge will be appreciated. Thanks in advance!!
- Jeremy
Jeremy in LA
- Jeremy
Re: Bealle/Axminster Collet Chucks
eaglesc
>The Beall has a larger Capacity 3/4"
Collets can be purchased from machine shops cheaper than available from Beall.
I have not used the Axeminster but those that opted for it like the profile. For some things it allows you to get closer to the blanks I.E. bottle stoppers.
I believe the capacity of the Axeminster is only 5/8ths.
I am not familiar with the collet type.
If you are considering the Beall.I originally purchased mine to make casing pens.I got the complete set of collets. I found that I normally use the 3/4 collet with a kerfed wooden sleeve to hold the casings for drilling. In this instance I didn't really need the other four collets.
I have since found a Myriad of uses for it.
In a pinch I use it to hold pen mandrels with the 1/4" collet. The 3/4 collet is the most accurate way I have found to drill to the center of a patterened glued up pen blank.
Re: Bealle/Axminster Collet Chucks *LINK*
Richard Allen
>Woodcraft sells a collet chuck for a lot less (I seam to recall $80). It is a Morse Taper attached chuck with 8 collets from 1/8" to 5/8" (for some unknown reason the set doesn't have 7/16" but all other sizes by 1/16" are included). The MT is threaded for a 3/8" draw bolt and will permit 5/16" and smaller stock to pass through the headstock.
Woodcraft - Lathe Collet Chuck
Re: Woodcraft Collet Chucks
Danny Wells
>The Woodcraft collets have a very weird taper. So don't buy the set thinking you can buy the 7/16 from another source, cant't be done and Woodcraft does not stock the 7/16 at all. I speak from experience. Other than that the collets and chuck work great.
Phil Joines Krum, Tx
>I use direct #2MT collets from Little Machine Shop. They can be had either singely for $9 or as a set of 7 for $50 . Sizes from 1/8 to 1/2 by 1/16ths. They need a 3/8" threaded rod draw bar.
http://www.littlemachineshop.com/products/product_search.php?critFast=collet+2MT
Jeremy in LA
>Thanks everyone for your responses! I need to get here more often because my posts get left in the dust! Thanks again - all of your comments really helped me decide what to do.
- Jeremy
