Duplicating Glaser Gouge Profile
Barry Turner
>I succumbed to buying a new Glaser 5/8" bowl gouge at the 2006 Symposium in Lousiville last month. Does anyone have a quick and easy formula for duplicating the factory grind using a Oneway jig and Vari-grind attachment? I normally use an Ellsworth grind on a Crown PM 5/8"as my primary tool. Thanks.
Re: Duplicating Glaser Gouge Profile
Jim Pugh, Ohio
>Barry, there is a technique for doing just that. If someone doesn't give it to you, get back to me and I'll ask my buddy to send it to you. There are about 3 steps as I recall.
Doug Thompson near Cleveland
>This might help.
http://www.woodcentral.com/articles/glaser1.shtml
You can easily figure it out...
Peter Teubel
>Wow, that sounded like a somewhat snide remark. Not intended, of course! What I mean is just play with the settings until you match the existing grind. It should take you all of 5 minutes. Here's how I teach it in my sharpening class:
Put the gouge in the vari-grind (VG), using the projection of your choice (I use 2" for all my jigs). Holding the gouge with the VG attached horizontally, loosed the VG set screw and let the arm fall to the lowest setting. Tighten the VG set screw.
1) With the grinder OFF, put the VG in the V-arm and adjust the arm in or out until the gouge hits the wheel. Now adjust the VG so the FRONT bevel angle of the gouge falls flat in the wheel. Secure the v-arm.
2) Rotate the gouge on its side. Adjust the v-arm out (or in) until the SIDE bevel lies flat with the wheel. Secure the v-arm again.
3) Rotate the gouge back to vertical and check the front bevel angle. Adjust the VG leg to get the bevel to fall flat on the wheel.
Repeat step 2 & 3 until both bevels will lie flat on the wheel when the gouge is rotated. Now blacken the bevel with a marker and test your setup by rotating the grinding wheel by hand and noting the scratches on the bevel. Repeat steps 2 & 3 again as necessary.
Once you have it, mark the v-arm and VG so you can get back to those settings easily. What I did is drilled an 1/8" hole thru the VG leg & body so I can insert an 1/8" rivet (not permanent) to instantly index that setting. Now all I have to do is adjust the v-arm to align the front bevel and the rest falls into place.
exactly how I do it-good reply
Re: One Problem
>The gouges sold in Louisville were mostly unground "blanks" that I saw. If Barry got one of those he has no existing bevels on his new tool to match up.
there's more
>I meant to add that when I want to establish a new type of grind I do the same thing but I start with a hand ground edge. I grind the front nose to the bevel I want. The I grind the side bevels to the angles I want both the sharpening angle(the one where the flute meets the bevel) and the length of side grind. This gives me 3 distinct planes. Then I will gradually joint these planes by grinding off the corners. This is how John Jordan teaches it in the AAW sharpening video.
After you've got this hand sharpened bevel(probabaly with a lot of facets unless your really good) go throught the VG alignment procedure that Peter described. I wish they would put a series of holes in the VG body that would work like a vernier gauge. It wouldn't be hard to do at the time of manufacture. They already have the notches at the bottom, if you had maybe 2 lines of holes, one set in the fixed plate and one in the moveable arm you could simply align the holes and have maybe 5 really accurately spaced divisions between each notch. This would allow you to easily dublicate grinds. I tried just scribing a line in front of the moveable arm and that works great until you want to change things and don't use that line. Then you scribe another line and after a while you have 3 or 4 lines that you are trying to keep up with. I don't do that much anymore. I have my one fixed position and if I need another grind I just do it by hand.
see my response above
Re: One Problem
>The gouges sold in Louisville were also oval shaped and not the "V" that Glaser used.
Give it your best.
Re: You type faster than me |;-}
>I use John's method to try a new grind angle from time-to-time. Instead of the line that either disappears or I forget what it stands for, I cut a piece of sheet metal to act as a gauge in the vari-grind's slot. Then I can write on the metal about what grind it's for. Necessary procedure with CRS.
I got lucky and won the draw :)
Re: One Problem
Barry Turner
>Mine was already ground to a typical Glaser profile. Its a 5/8" V-15. As legendary as Glaser steel is, that factory edge won't last me forever and I'm trying to figure out how to duplicate the grind. I've had a Wolverine jig adn Vari-grind for a while, but still don't understand all of the geometry that is involved. I've been using an Ellsworth grind on my Crown PM, so I may just switch to that grind after a while. Thanks.
Richard Allen
Re: One Problem
Richard Allen
>Hi Barry
Set you extention to something that is easy for you to set (likely the same as you set for your Ellsworth jig, perhpase 2")
Adjust the "V" arm so the nose bevel is matched.
Tilt the tool/jig to the side and adjust the angle of the Variagrind si the wing bevel is matched.
This will almost certinaly change the nose angle.
Adjust the "V" arm for the nose angle.
Re-adjust the Vari-grind for the wing.
Go through the process a few times until you are satifyed that the nose and wings will work.
The "V" arm is adjusted for the nose and the vari-grind angle is adjusted for the wings.
Grinding the tool the same way as your Ellsworth gouge is a good idea.
Re: One Problem
Barry Turner
>He didn't get one of those. He got what looks like a traditional Glaser 5/8" bowl gouge with the Glaser grind. So I do have an original bevel to use as a guide. The shaft is not oval.
