Powermatic 90 Disassembly
>Hi everybody! Can anyone tell me the best/easiest way to disassemble the headstock on my Powermatic 90? Thanks.
Here is a link to the manual *LINK*
Keith Newton
>Just click on the blue highlight, and download the whole manual.
http://www.owwm.com/pubs/detail.asp?id=899
Re: Thanks, but,,,,,,
>I have the manual. What's stumping me is how to lock onto the handwheel and keep it from moving while I turn the nut.
Keith Newton
>If I understand what you are asking. Mine has a locking button just to the right of the speed changer/switch. Just press it in while you rotate the arbor to find the locking point.
When you get the left end casting off, you will find that is just to cover the belt, and pulleys. I think you will have to work from inside the cabinet to get at bolts from underneath up into the headstock, although I have not done this, so I am not sure.
>My spindle lock is inoperative. Something has happened to the speed control and I can't get it turned slow enough to allow the spindle lock to engage.....I think I'll try chucking a piece of scrap tightly and then try to jam the scrap against the tool rest. Hopefully, that will lock the spindle.
Ron Bauman
>Frank: I've got a 90 that I'm rebuilding (over the past couple of years). If I understand, your trying to remove the hand wheel at the rear of the headstock? I have in the past done it by locking a pretty good sized crescent wrench on the nut part of the hand wheel and whaking it a good shot (in the right direction) with a hammer. If you hit it at the far end of the wrench with a sort of snap you can sometimes get the wheel to loosen a quarter turn or so and then just spin it off. I replaced the bearings in the headstock and there are some things they fail to mention in the manuals. Also the threads on the spindle on the outboard side tend not to be what the factory says they are. I'm in the house right now so I can't check to give you an accurate fact as to what they are, but if you need further help email me and the next time I go out I'll get them for you. What, exactly, are you doing? If your speed control is messed up, there are two variable speed pulleys that do the job. One is controlled by the big dial dingus on the headstock and the other by the pressure exerted by the first on the flat belt. They may just need some grease to improve their sliding. Anyhow, email me if you need to.
Re: Thanks, Ron. Sent you an email.
