We value your privacy.
>Has anybody ever sand blasted their work? I have on a few pieces both times I've been at Arrowomont. I've been wanting to do some more but didn't have a sandblaster available. Yesterday I was up at the new Harbor Freight store by my house and they had this one on sale for $19.99 from $39.99. So I figure what the heck! I'll use a heavy cardboard box to do the blasting in the back yard and see what happens. Has anybody used this one before? I'm anxious to try it. Hope it works!
>Jennifer I bought the same thing a while back but haven't had the time to try it out. Mike Lee told me he does this and just places the project in a plastic bag and captures most of the abrasive in the plastic bag.
I've heard that you can use a paper or plastic bag....that might be better that a box actually? I'd liek to devise a way to see what I'm doing though? Perhaps a plywood box with a piece of lexan covering a hole cut in it?
I'm hoping to get some turning time in next week. I've been on a way too long separation from my shop and way too many consecutive days here at work. Tomorrow night marks 11 in a row, and then I'm off for 3 days. Finally!
>Yes I have blasted quite a few pieces. It works real good on coarse grain woods like oak and especially ash. By blasting a piece it brings out the soft wood between the grain. Also I dont put a finish on the piece after blasting. I tried appling a finnish but I didnt care for it. Craft Supply had some blasted pieces on the front cataloge one year. I dont remember which year is was put it came out just a few months after I did my first piece and it looked like I had copied them. Give a try
>I need to buy the abrasive and then think up a project. I have too many other projects right now. Someday I'll have the right project in mind and then I'll have it. Hope you are successful.
>Krylon Fixatif is a spray finish that works great on sandblasted woods as well as wire brushed woods. It doesn't change the appearance at all and protects it.
>Just a word of caution on the subject of sandblasting. The use of sandblasting media that contains silica can be very hazardous to your health.....and even the health of bystanders. Silica can be a health hazard when inhaled. "Overexposure to dust that contains microscopic particles of crystalline silica can cause scar tissue to form in the lungs, which reduces the lungs' ability to extract oxygen from the air we breathe)". Silicosis is not reversible. Once the damage is done........its done.
With a little help from Harbor Freight, it seems you can get into the sand blasting business rather quickly and cheaply if you already have a compressor.....but please don't skimp on the PPE (Personal Protective Equipment) like a respirator, hood, etc.
Good luck with the sand blasting. I think. don`t know but think you might be better off with tempered glass or just regular glass if you are building a blasting cabinet. I would think that the sand will dull and or discolour the laxan.
Something to consider for the more artistically inclined would be a pencil blaster. They are hand held like a woodburner or engraver and have very fine tips for doing detail work. I used them when I did glassblowing for removing small impurities in glass and for etching designs.
>I have got one of those that I have not used also. I had one a long time ago that I got from Sears that I wore out. I was just using it outside and letting the sand go. I was using a full face shield, and respirator, but still this is very dirty work. You will defiantly want a shower right after.
I was thinking of using a big cardboard box that I can tape a glass window in, with hand holes under to work through, and run a shop vac in through a hole in the top to take the blasted wood-dust away, and keep the sand particles inside with a negative pressure inflow.
Even though I have a pretty large shop, I would like to be able to fold it up when I am through and shove it into a bend somewhere without having a big chamber taking up shop space.
>Barry is so right. Do not try it without GOOD protection and a good respirator. Several years ago I built a blasting cabinet for small parts that needed cleaning, and I have used it since on a piece of cedar that had a lot of bark inclusions, but that piece was turned after blasting out all the bark pieces. It worked like a charm.
>Where does one find such a pencil blaster? Sounds like something I would be interested in. I have seen small blasters at Michaels and Hobby Lobby stores that are propelled by freon cannisters. It that what you are referring to as a pencil blaster?
That's just what I have been looking for. They wanted $50.00 for a kit at Hobby Lobby and it was the freon can, a plastic nozzle and either 4 or 6 oz. of media. That makes the pencil blaster a really good deal.
>Howdy Jennifer: Funny you should ask. I searched for months for a Sand Blast Cabinet before buying one from Tractor Supply for about $110.00. Much better quality than the HF cabinets. A couple things about the cabinet. You use the sand over and over 'till the sharpness wears off. You contain it so you don't need a hood, etc. You have a plastic top so you can see what you're doing (you can get self sticking film kinda like heavy duty Saran Wrap at HF & other suppliers which you stick to the inside of the top keeping you from blasting the inside surface of it), and it has a light inside which is a real plus. HF also has some "sand" in the form of Aluminum Oxide and Glass Beads I believe. These are pretty fine abrasives at 70 grit and leave a fine, almost velvet, feel to the wood. You can get other types of sand, such as Silica Sand (note previous cautions) elsewhere but I've not found a source near where I live. But Silica Sand comes in coarser grits which would be benifical for heavier duty work.
Sorry for the long post. Good luck. And please post a picture of your results.
>I used a blast cabinet to clean car parts when I had a custom shop. The sand will erode either glass or plastic. I used .100 lexan and replaced it when it got too bad.
I've also blasted turnings. 1 quart blaster from Mac Tools that I've had for several decades. Used without a container mostly on Redwood. It worked well. The areas I didn't want eroded where covered in duct tape. The sand was a white play/blast sand from Elliots Hardware in Dallas. I think it was about $5 for an 80lb. bag.
You really need a blasting hood. It covers your entire head to the shoulders. I thing HF has them. Use a good respirator too.
Unfortunately I don't have any pics and fortunately they have all been sold :>)
