Re: Pen Kits
eaglesc
>"I;m looking for a pen that has a cap like a fountain pen but is a ball point pen. Not a roller ball or fountain pen. I can find twist mechanisms and roller balls and fountain pens but not that style in a ball point with the cap separate. Thanks for the help. "
O.K. you got me curious so I took apart a "Baron" RB which is a pen that is uncapped and posted (or not) while writing.
In comparing the refill with a "PArker" style refill the RB roller ball is longer but has a shorter "recessed section" where the spring is located.
I believe a bushing could be made so a PArker refill would work in a capped type RB kit with the use of a longer spring in the upper section but for the life of me I don't see the benifit of a PArker type ball point refill as opposed to a RB refill.
Perhaps that is why it isn't available.
One suggestion you might try.
Rather than looking for a different kit that may not exist, have you considered looking for a ball point refill configured to fit a Roller ball Style Pen?
There are many different refills available from different companie.some may have the configuration you are looking for.
