Finishing Purpleheart
Ricco G
>Hi I am going to turn some pens out of Purpleheart, what is the best way to finish them to retain the purple color. I was told some finishes will darken it. Thanks Ricco
Ricco G
Re: Finishing Purpleheart
Gordon P in Sumner, WA
>I have made a pens using purpleheart [pretty nice, too] but sadly Purpleheart will darken over time, especially if exposed to sunlight. If the finish you are using has UV inhibitors, it will slow down that reaction.
You might be better off using something like tulipwood, redheart or other lighter colors, or use a white colored wood and dye it purple using aniline dyes.
eaglesc
>PH will often turn brown while turning.( reaction from heat, not light)
When I first started using it I would hang the finished pen in the sun a couple of hours prior to finishing,
I have since found that if I lay the finished pen in sunlight or even light from a lamp the color will return.
This is a multi laminated pen a year old that was an "experiment.
There is PH, bloodwood and yellowheart on a flaming boxelder blank.
The color is as vibrant today as it was a year ago, virtually no finish on this pen.Most of the wood is impregnated with CA, a little buffing with TSW shines it up
