Jet Mini Ballast � Headstock
Brian Hahn in SW Wisconsin
>John's recent posts finally prompted me to post one of my improvements.
This spring I was doing a lot of off-center turning that had my Mini dancing. My solution was to add some weight to the headstock and tailstock. The weights are lead cast in an aluminum mini-loaf pans and weigh about 10 pounds each. Two stove bolts run through the headstock weight and are anchored by a piece of flat steel bar stock in the bottom of the pan. The bolts extend beyond the base of the weight and through two holes in the headstock casting. Bolting the weight to the casting keeps it from doing its own dance and dropping on my toes.
Re: Jet Mini Ballast � Headstock
Re: Jet Mini Ballast � Headstock Detail
>I filed the top of the headstock flat so the weight had a good flat surface to sit on. Getting the nut on the front bolt is a real pain and I would put it in a different position if I did it again.
Jet Mini Ballast � Tailstock
>Same type of weight as the headstock, except the stove bolts are only acting as pins and the weight is epoxied to the tailstock. There are two bolts on the front end, one on either side of the quill, because that is where the casting was thick enough for me to drill without worrying about interfering with the quill.
Nice job, but a lot of work
Craig Daymon
>When I was doing eccentric turnings on my Jet mini, I just clamped the lathe to the bench with a quick clamp. Worked great and I had the speed set pretty high.
-Craig
>Interesting Brian. That's one more thing I may have to look at for the ultimate mini lathe. How about an 8" riser block for the headstock and tailstock + extension for the tool rest. Then add 500 lbs of lead keep it from rocking. Oh wait a minute, I already have that in my Powermatic. never mind. :) I do get carried away sometime.
Ric Taylor
Mini Lathes are Taking On a Life of Their Own
Ric Taylor
Carole Valentine
>I'm confused. (Not unusual!) Is your lathe not bolted down?
Russell L. Babbitt Jr.
>Not very pretty, but I'm sure it works. For others I would suggest building a small stand or base, fastening the lathe to the base and put the weight in/on the stand.
>The lathe is bolted to a home-made stand. The beam that the lathe is bolted to is a hollow box-beam and it is filled with sand, about 100 pounds worth. I didn't want or need another bench taking up space in my shop (I currently have 4 different benches, each of them fully committed.)
>That definitely is easier for most situations and is a more conventional solution. My mini is on a weighted stand (see my response to Carole) and I found that I needed more weight. Mounting the weight directly to the head and tail stocks actually maximizes the effectiveness of the weight without inducing new modes of vibration. And lead is nice because it is a fairly "dead" material - it doesn't ring worth beans when you strike it lightly.
>Years ago there was an interesting thread going on about the advantages of weighting the heastock vs weighting the stand. I don't remember all the story because they got very deep into the engineering. Weighting the headstock had some advantages but the dissadvantage was how to do it affectively.
I think Gerry Glaser did some experimenting with a weighted cantelever arm that was mounted off to the side of the headstock or at least to the bed near the headstock. Once adjusted properly it completely stopped the vibration but had had to be adjusted when the weight of the piece changed from turning.
Allen Neighbors
>I read a post not long ago, about what you described, John. It was about the weight being above the headstock being more effective, and the photo I saw showed the weight on the top of a rod or pipe and about three feet above the lathe. I can't remember where I saw that. But they got into the engineering part of balance and vibration. The man could put a block of wood on that was out of balance and still turn up the speed.
Allen
>You have definetly made yourself a heavy duty mini.
>Moving the weight higher above the headstock does have advantages. Basically, the lathe rocks on it's feet and the further the weight is from the feet, the more effective it is. (Inertial moments and all that.) However, extending the weight above the headstock introduces a new factor - the stiffness of the arm the weight is mounted on. If it isn't absolutely stiff (or darn close to it), then the weight will start whipping around at certain frequencies. This can be overcome, but why bother. Mounting the weight directly to the lathe's headstock and tailstock castings eliminates any coupling problems and seems to give "the best damping for the buck (or pound)".
>But it's still only a mini and always will be. My big lathe doesn't feel threatened by these improvements. ;=)
Jim Underwood
>That's hilarious Brian!
Thanks for sharing.
Re: Jet Mini Ballast � Headstock *LINK*
Ronny Eelen (Belgium)
>Found this....
The higher the weighth....
RevDoug
>That's the article that I keep seeing when this question comes up. I still think that for most of us applying weight directly to the head stock as suggested here we can take care of the bulk of the shakes. 8)
Turn 'em round,
Re: That's the one, Ronny!
Allen Neighbors
>That's the one I was referring to in my above post. Thanks, Ronny.
Allen
