2" Beall ball set
2" Beall ball set
2" Beall ball set
Dayl Gable
>Has anyone found a slick way to mount the threaded ends of the Beall balls to a flex shaft or air powered die grinder? I was thinking of hunting down a machinist willing to make something with the nesessary female thread and a 1/4" shank. I am trying to buff deep inside a irregular surfaced carved wood vessel.
Re: 2" Beall ball set
>Dayle I haven't done that but I did turn some adaptors for my tubular sanding drums so I could use them in my flex shaft. I had to turn the big ones out of solid steel but the smaller ones I made using all-thread couplers. I found a coupler with the right size thread and then bought a bolt to fit the other side. I cut the head off after screwing it in the coupler. I drilled through the coupler and bolt the same size as a nail that I had and drove it in to lock the bolt in place. Then I turned this down to 1/4". The same thing would work for the beal buffs but I don't remember the thread size. Probably somewhere around 5/16 I think.
You might try looking in the Rio Grande catalog. They have all sorts of buffs that fit flex shafts.
I have a bunch of Dremel buffs I use for really small stuff and for reaching into really tight recesses where the Beal won't go.
Yup...
Peter Teubel
>I have a flex shaft which is powered by a drill. The flex shaft has a 1/4" Jacobs chuck at the business end. I just put the ball buffs in the chuck. I don't care if I mangle the threads because I only use the buffs in the flex shaft.
Re: Yup...
Roger
>Peter,
Where can you get a flex shaft for your electric drill? I could use one for applications other than buffing. Thanks.
Roger
woodworkers supply
>Woodworks supply has a heavy duty one that fits in a drill. One of my friends had an adaptor made so he could connect it directly to a 1725 rpm motor shaft. That's his main carving tool.
Here it is, wasn't too hard to find  *LINK*
http://woodworker.com/cgi-bin/FULLPRES.exe?PARTNUM=116-753
Re: Yup...
Rick Allen
>Home Depot and many other places. It is a Delta branded product which is designed to attache to some of their small benchtop belt/disc sanders.
These are not meant for high speed or extended time use. It often sells for about $30.
This is a poor subsitute for a Foredom but it is also cheap enough that being wrong won't hurt to much. And you are very likley going to get $30 worth of use out of it anyway.
Re: Yup...
Dayl Gable
>Yup. I got a flex shaft like the one shown. The problem with it is the chuck is to small to mount the threaded shaft on the ball. I didn't measure it but the OD appears to be about 3/8". I'm toying with the idea of sanding the shaft down freehand but I know till I'm done the things going to have a pretty bad wobble and the ball would be toast. I like the idea of messing around with threaded couplings though. Since I don't own a metal lathe, I suppose I could chuck up a short piece of all thread on my drill press abrate it down to a 1/4" reasonably accurately then I could turn it into the coupling and mount the whole thing in a 1/4" collet.
Re: Yup...
>Dayl Get a brass bolt to put in the coupler. Then you can turn it down on your wood lathe using HSS tools.
Woodcraft has them...
Peter Teubel
>...but I can't see it online. If you have a store nearby, check it out. The one I have has a 3/8" Jacobs chuck.
Actually...
Peter Teubel
>Yes, 3/8"...not 1/4" as I posted originally.
Re: Yup...
Dayl Gable
>Thanks! Good idea.
Re: flex shaft.
Dayl Gable
>That's something to check out,the one I have is 1/4". But really from my experience that kind of flex shaft heats up real quick under any kind of laterial heavy load, maybe the 3/8" one is a bit more robust. It would really be my #3 choice for trying to run the ball.
Not exactly,
Keith Newton
>what you ask for, but something similar for the same end.
I mounted a right angle air die-grinder on the end of a 20" pipe nipple with a elbow on the other end and a ball valve > quick-connect air line. I taped the air trigger down, and use the little sanding disk that came with the 2" arbortech head on the air-grinder. This disk came with a cloth abrasive glued to it, I pulled that off, scuffed the plastic face then sprayed it with high tack contact cement. I can punch out my own disk to about any size from the gold peel and stick. and they stay on and last longer than I had expected.
When I use this, I hold it loosly with my left hand near the rim, and my right hand on the valve which is at a right angle to the length, which gives good direction control on the other end.
If you had trouble following this, I can post a photo if anyone needs it, or send me an email for more photos. Although, I really should write an article if nobody else knows or uses this, and if there is enough interest.
Re: Keith, Allen's interested!!
Allen Neighbors
