Kelton Angled Faceplate and Eccentric Faceplate?
Craig Daymon
>Has anyone used the Kelton Angled Faceplate or their Eccentric Faceplate?
Anyone know if these are available in the US?
I suspect the Eccentric Faceplate might cost a good bit, but the Angled Faceplate looks like it might be reasonable. I like playing with eccentric turnings once in a while and these look like they might be useful.
Looking for opinions. Thanks in advance,
Craig
Re: Kelton Angled Faceplate and Eccentric Faceplate?
Fog Tanner
>One of the members in the woodtuning club I belong to has the angle face plate. He did a demo with at a recent club meeting held at his studio. It is not for the faint of heart of small pieces of wood and light duty lathes. I spent some time after the meeting looking over the angled faceplate, thinking about getting one. The only problem with it, is it is intended for larger pieces of wood (16" is on the small side). The faceplate is either 8" or 10", really designed for large pieces of wood. Its a fairly massive assembly and you need a lathe with good headstock bearings. I had talked to Steve at The Cutting Edge, and he can get them should I decide I want one.
An alternative for smaller pieces is the new Escoulen chuck. I now have both of his chucks to saitisfy my offcenter wants. It fills the smaller size area where the Kelton is too big. The new chuck allows you to turn both eccentric and offcenter, either seperately or combined. I have made some eccentric bowls and now working on 7" bowl that is both eccentric and offcenter.
Re: Kelton Angled Faceplate and Eccentric Faceplat *LINK*
Dinyar Chavda
>Craig:
Ken Grunke had shown the chuck he had made on WoW,-- see link below and the next picture, and had offered to make one if someone wanted to buy it. You may want to contact him if he does not respond to your post.
Dinyar
Grunke pics
Ken Grunke from SW WI
>Thanks, Dinyar.
In case I'm accused of commercial advertising here, which I have done my best to avoid, I'm not in the business of making eccentric chuck doodads. I do make occasional prototypes, however my design has only lateral adjustment, not tilt.
My eccentric chuck adapter
Craig Daymon
>Dinyar,
I've seen Ken's faceplate before and it looks well made, but does seem restricted to only using the screw for attachment. The Kelton would allow me to attach a chuck which would offer greater possibilities. The Angled faceplate from Kelton is different from Ken's and not nearly 10" in diameter. Ken's is more like the Eccentric, though much more compact than the Kelton Eccentric, which appears to be quite massive.
Thanks for posting the link, but I think my invitation to WOW expired some time ago. Although I found it interesting, I find WoodCentral much easier to check on a regular basis.
-Craig
Thanks all for comments and input.
Craig Daymon
