jet mini index
jet mini index
Re: jet mini index -oops
>Must have an excited mouse. Here are some photos of the modifications I've made to the Jet mini. This one is the index system I added. The index wheel is black plastic. I drilled 36 holes. I made all the various parts. The lathe already had a hole that was threaded 10x 24 so I used that to screw the purple heart block that locks the index pin in 2 positions, on and off. I drilled through the lathe for the index pin. Both sides of the pin screw into the coupler nut which is 10x24. I will be publishing complete plans on the internet eventually so this is just a preview.
jet mini index -off
Jet mini spindle lock
>Here is my version of a spindle lock for the jet mini. This way it doesn't take 2 hands to remove a chuck.
jet mini tool rest
>The jet is a good lathe but I've seen many of thier tool rests break so I built my own out of solid steel, no casting.
There are other modifications I've made to the lathe to improve it's perfomance. Look for an article If I can get someone to publish it.
Re: jet mini tool rest
Bill Stehman
>John, all very creative ideas and well executed.
Re: jet mini index -off
Jennifer@Indy.USA
>Dang, John...some great alterations to the mini! Nice job on them....they look like they not only function great....but are nice looking as well. Thanks for sharing your hard work with us...well at least the results anyway :)
Jen
Ron in Drums PA
>Nice John,
How do you go about drilling 36 perfectly spaced holes?
>Ron drilling was easy, marking them off equally was a pain. I put the divider locking pin in place and let the point scribe a circle o the plastic. I usually just walk the dividers around the circle until I get it divided exactly. This time it kept coming up off so I turned a wooden square with a center cirlce that fit the plastic hole. Then I used a compass and ruler to mark of 2 lines perpendicular to each other through the center. Then I marked off 9 spaces instead of 36. I checked them twice to make sure the were perfect.
Then I took this same board and clamped it in a vise on the drill press. I drilled very small holes at each marked spot with a tiny center drill. Then I drilled them with the 3/16 drill. All I had to do was rotate the plastic disc on the wooden centering guide.
Jim Underwood
>Very nice John! I'll be looking forward to the instructions.
I've made a knock-off in 1/4 melamine of the indexing wheel from that Anglefire site (or whatever the name of that site is) where you can buy those plastic ones for about $20.
I've not thought of putting it on the handwheel side before. Makes sense though. I did think about putting the a locking pin device in the same place though. Just didn't get a round tuit yet!
I really like that chuck lock idea! I've been a bit aggravated with my Nova Midi Chuck lately. It keeps getting stuck and if I put a rod in the spindle hole and bump the chuck it gets a burr in the scroll mechanism and I have to take the chuck apart and clean it up to get a smooth action again. I keep wondering why that happens. I've finally put one of those plastic washers under the chuck to keep it from sticking so bad...
Re: jet mini index -oops *LINK*
Gil Jones on Lake Seminole GA.
>Check out this site. Aside from some beautiful segmented work, there are downloadable pdf files that will print an 8" wheel that has been divided into between 12 and 50 segments. Print it, attach it to your wheel, and drill.
http://www.smithart.us/download.htm
>Jim Get some air tool oil and put it on the spindle. Then wipe it off with a paper towel. be sure to get some on the flange where the chuck bottom out. It will leave enough residual oil to reduce the chance of sticking. On my Powermatic and my older Nova mini lathe if I use the oil on the spindle my chucks never lock up.
If thought about bending the metal so the part where the hole is would be very close to the spindle but it can be a hassle for the average person to bend this stuff and I wanted all these projects to be easy to build. The tool rest of course was different.
now you tell me :) great link
Jim
>Gil,
When I want to do something like a dividing head, I just draw it in AutoCAD and output to the CNC router. It's more precise than I can drill it by hand. Once I have the program, I can output as many as I like, or modify it and have another program to run again.
Yeah, I know, I cheat. But I'm using the tools available....
Ken Grunke from SW WI
>John, you're coming out with all this useful info and tips, you ought to have your own website! Or a special section here on WoodCentral--how about it, Ellis? ;-)
The computer printout idea that Gil posted is a great one. We don't need super accuracy for our purposes, but to get the best you can, use an automatic centerpunch before drilling the holes. This is a pen-sized, spring-loaded doohicky available at most any hardware store. General is the brand, they make other precision tools like dial calipers, scribers, rulers, etc and are usually grouped together in the store--on yellow cards. You don't need a hammer to use them, just place the point on the mark and push the body down until the spring releases and voila, you have a little dimple right where you want it. I usually give it a couple more hits for a deeper dimple.
Then start with a small drill bit in a drill press for best results before drilling the final size. Or use a pilot-tip bit, with a smaller tip on the end--I think either Black & Decker, Dewalt, or Irwin makes 'em.
Re: jet mini index *LINK*
Fred in NC
>Last year I made an indexing setup that does not require any alterations to the lathe. I made a few extras. See the link below, which has a pic and description.
http://www.woodcentral.com/cgi-bin/classifieds.pl?read=6296
Re: jet mini index
>Good job Fred. I thought about doing it roughly that way because that is the way I have the powermatic set up. I decided I wanted it permanantly installed and out of the way. Your method is easier.
