How to remove bark from burl
keith zimmerman, Normal, IL
>I bought a wonderful piece of maple burl at Louisville and was wondering how best to remove the bark from the burl.
Any ideas?
keithz
Any ideas?
keithz
This is what I do....
TDaniel
>Most of my burl pieces are turned natural edge up. After I have turned the piece to almost final thickness I use a pick to remove the unwanted bark.
TD
Re: How to remove bark from burl
Ric Taylor
>You can blast the bark off with a high pressure water spray like those at a car wash.
Ric
Bart Rhoads
>If you soak the burl in a tub of water, bark side in the water for a couple of days, it will blast off a lot easier. I have done this with mytrl burl several times so it should work on maple burl also.
Brad Vietje
>If green, a rubber mallet usually works very well -- smack the wood at a slight angle and chunks of bark come off without damaging the fine points below. this works great for Boxelder and Cherry burls, at least.
If dry or nearly so, I like Terry's suggestion about pulling/picking it off later. If you don't want a natural edge, then I can't help -- I'd probably try the pressure wash method mentioned, but never have.
Safe spinning,
Brad Vietje
Newbury, VT
