THE WOODRAT IS BACK!
Whistle
Whistle
Whistle
Jim Rutten
>I recently made my first whistle on the lathe and it made me wonder whether you could make a dog whistle on a lathe? Would the hole be shallower? Just wondering what you thought.
Re: Whistle
Re: Whistle
Pete in Holland, MI
>Whistle diameter dictates volume. Whistle length dictates frequency. The shorter the whistle, the higher the frequency. Think about a pipe organ.
Re: Whistle
Re: Whistle
W.C. Turner
>I made some whistles some time ago. Only problem is, they would not whistle. Musta done something wrong.
How do y'all do it?
Any good websites showing the making?
W.C.
Re: Whistle
Re: Whistle
Jim
>You have to cut the fipple just right to get a whistle. The fipple is the half circle piece that is inserted into the mouth piece end just up to the notch. I normally drill, cut the notch and then cut the fipple to fit the notch. If it doesn't work as well as I like, I cut another one until I get a good sound. Once I get the sound, I glue it in place.
There may be some instructions somewhere on the internet that explains the principles involved. I normally just fiddle with it til it works.
Re: Whistle
Re: Whistle
Jim
>http://www.countrylovers.co.uk/fun/whistle.htm
http://science.univr.it/goccia/whistle/index.html
Here's a couple of links that should get you going.
Re: Whistle
Thanks....
W.C. Turner
>for the links!!
As mentioned, I made some before, & just never got back to trying again.
