Unaxol gloss pen *LINK*
eaglesc
>I don't know wherer I read about this stuff, but I contacted the company and got a sample to test.
They sent me material to spray as I normally spray Deft lacquer with an HF air brush.
The sanding seal dries in less than an hour and comes off easily, does not gum up MM.
The high gloss recoat is one hour.
I chose a tough piece to start with, crotch walnut.
The learning curve wasn't bad, this is the first attempt.
The surface is a clear as CA but with a warmer feel.
Picture taken with flash.
http://www.mobydicksupplies.com/
Re: Unaxol gloss pen *LINK*
Chuck Engstrom
>That looks great! Here's a link to sales and info on another water-based lacquer at an instrument maker's supply website -- Bin Pho mentioned the site (specifically their metal acid dyes) in L'ville. It also looks pretty interesting, and I may give it a try.
Best--
Chuck Engstrom
Chestertown MD
KTM9 H20 lacquer at Luthiers Mercantile
RevDoug
>I've been shooting some of this on some bowls. I really like the sanding sealer. Was able to smooth out a plywood bowl with only two coats. Came out really smooth. Haven't sprayed any lacquer in 30 years. This stuff is thin and takes no thinning. Goes on quick and clear.
Turn 'em round,
eaglesc
>I followed the link you posted and two things I noted.
Cost,Unaxol much less expensive by the quart.
Description,"lacquer like"
Not sure what "lacquer like" means but they felt the need to use it.
Chuck Engstrom
>I was wondering a bit about price comparison, so thanks for that.
As to "lacquer-like," I'd have to say I paid less attention to that than to the apparent satisfaction and extensive information from the guitar makers. I expect that their standards for finishes are at least as high as turners', if not higher.
Link to KTM9 manufacturer's site below, FWIW.
Best--
Chuck
Grafted Coatings -- mfr of KTM9
eaglesc
>Being a former professional guitarist and presently a pencrafter I would have to say the two have similar requirements to finishes for different reasons.
The pens I sell the most of are those with a High gloss almost "platic like finish" people are like fish, they like shiny objects.
As a guitartist I wanted my instrument protected but did not want the finish to diminish the quality of the sound.
Most of the instruments I see for sale today have a thick plastic like finish on them.
That goes to the marketing demographics and not as much as the quality of the sound out of the instrument.
That's my take.
