beall buffing adventures
jared
>Hello: I bought a beall buff kit, the 8 inch wheel kind, last winter when it was on sale. I never got a round to using it until yesterday. I spent two hours and tried three different electric motors to mount the aluminum arbor on. The first motor worked fine when I tried it but then I discovered that it turned the wrong way and apparently the rotation can not be reversed on that one. Then I hunted around and found another motor but lo and behold it was a 3450 rpm, not recommended at all to use that speed. THe third motor I found in the barn, I never could get to work right. So there I am in my shop, trying to decided what else to mount the buffs on. Then a light went on in my thick head, there stands my lathe, the rotation is reversable and the speed is variable, perfect. I just mounted my bowl chuck on the lathe and clamped the aluminum buff arbor in the the chuck. It worked great but I do want to get the shaft extension so I can get inside the bowls better. Has anyone else ever resorted to this sort of thing? Jared
Re: beall buffing adventures
turn the motor around?
TDaniel
>If you can't reverse the direction of the motor rotation you can reverse the motor by simply turning it around, space permitting.
Carole Valentine
>They have A Morse Taper that fits the Wheels. I do all my buffing on my Jet Mini.
Brian McKearney
Re: turn the motor around?
Brian McKearney
>I agree with TD - just turn the motor around. I did this with one of my old grinders - I unscrewed the base, rotated the motor and reinstalled the base. So, now I have a grinder that turns in the opposite direction and the switch is still on the front where it is convenient to use. Should be a pretty simple task.
Brian
eliot
>I thought that most people used their lathes to rotate the Beal buffs. Obviously, there's more than one way to do it.
I also use the morse taper Adapter
Jake Niedling
>in my lathe. It works well for me. No space to add another bench and a separate buffing station.
Russell L. Babbitt Jr.
>Keep that 3450 motor. Beall recommends that speed for their bowl or goblet buffs.
>Jared I use the aluminum extension on my lathe. It sticks out further than the morse taper adaptors. I think I got it from Craft Supplies. It screws on the spindle so you have to buy it threaded for your lathe.
You can also get morse taper extensions that you can use with the Beal morse taper adaptor.
Don in Central Illinois
>I'm confused. I thought the Jet mini only had about a 5" clearance between lathe center and bed (so you could turn a 10" bowl). I thought the Beal buffs were 8". How does it fit? I have an old Delta with a 5" clearance and haven't bought the Beal system because of that. TIA.
Tony - Memphis
>I'm using the Beal system on my Jet mini. I have the ~$89 set from Woodcraft.
Tony
8" diameter = 4" center to bed
TDaniel
Re: 8" diameter = 4" center to bed
TDaniel
>that would be the required space of 4"; you have 5" so it will work.
>Thanks. The light finally went on!! I had a serious senior moment there. For some reason I was equating the 8" diameter as 8" radius. Sorry for the confusion, but the more I post, the more ya'll will realize that my senior moments are coming faster and staying longer.
Don't worry Don....
TDaniel
>a new body and mind is just over the hill :)
Re: Don't worry Don....
>Amen.
Jim Driskell
>I manufacture the Wood N Things buffing adaptors sold by Craft Supply and Packard as well as donpencil.com They screw onto the lathe and extend the wheels 8" out from the headstock Giving room to buff large bowls and the variable speed advantage of the lathe without the problems of the morris taper coming out at the worst possible time. Also not requriring the cost and storage space of a decated buffing motor.
