Re: Any ideas?
>You didn't tell us where you are located, or whether the tree came from woods, roadside, fence row, orchard or residential lot. These clues can make a world of difference in our ability to identify the wood, or at least eliminate a lot of impossibilities. Not needed in this particular case, however. It is a member of the genus Prunus, which includes the cherries. From the color, this one is most probably a plum. Which variety cannot be determined; It is probably a hybrid. Too bad, but the striking coloration is fugitive, which means it will fade, probably rather quickly. It is pretty unstable, and you will find that it has a very strong tendency to check as it dries.
Pink dogwood has a pleasant pink wood coloration under the bark, too, but that also fades over time. This one is not a dogwood. The bark and the dark sapwood are all wrong.
