CA "finish" question...
Jeremy in LA
>I had to reinforce/repair some checking on a Bloodwood urn as I turned it, and due to the moisture I found as I went along and hollowed it, I decided I'd do a "CA soak" inside and out, just in case.. now I'm faced with a situation I've been in before.. As I sanded the outside, I noticed spots that appear to be more saturated with CA naturally take a higher polish than the other spots. I sanded thoroughly to 600g until the surface was uniform (no CA bumps), but I still am faced with shiny spots. I left it in the chuck and buffed with tripoli/white diamond to see how things would blend, but they're still there - as they have been in the past on some pieces. Any way around this? Do I just need to sand more and more? Any thoughts would be appreciated. Thanks!
- Jeremy
Re: CA "finish" question...
adrien
>From "Articles and Reviews":
CA as a Finish
by Ron Parsons
I use water thin CA and keep it in the fridge to make it set slowly. After sanding to 600 grit, with the lathe spinning slowly I apply the CA right out of the bottle and spread it out with a little brush. I let it sit (with the lathe continuing to spin) for a few minutes. Then I grab a handful of shavings and burnish it in while I speed the lathe up, and sand in steps to 3600 grade Micro.
Jeremy in LA
>Thanks Adrien (& Ron). I guess maybe joinin it instead of trying to beat it might be my best bet on these occasions.
- Jeremy!
Lan Brady
>Jeremy,
I have to stop my lathe to apply CA.It will not run that slow. I use to have the spot problem.
I now apply completely then sand back to wood and apply again.
Sand with 320 then 400. apply another coat.
sand with 400 and 600. Apply a 4th coat and wet sand with 600.
now I go through the buffing, do not see the spots any longer.
good luck, Lan
Jeremy in LA
>Thanks Lan for the steps. That should also really help. Do you use thin, medium or thick when you apply? Thin is nice because you can spread it so fast, but obviously thick means more time to work. Thanks again! - Jeremy
Lan Brady
>Jeremy,
I use very thin. . Also, I use polyester batting(pillow stuffing from XXX-mart). A small pinch of batting pinched in forceps makes a good applicator. Use 3 or 4 drops of the CA and wipe in circles. Do not let the batting run completly dry or it will stick.
Clean up----I keep several forceps . When the CA dries on the forceps, just bend the batting off and you are ready to go again, CA glue has no shear strength so it will break off the forcep grips easily.
