Wooden collet chuck
Wooden collet chuck
Wooden collet chuck
Jeremy in LA
>Hi! I saw plans for a homemade wooden collet chuck in a magazine a few months back. Didn't buy the magazine, and I remember enough of the design to make my own. Does anyone have any wisdom/experience they'd like to share?
If I remember correctly, the general design is built to fit into a standard chuck, stepped on the outside with a hole in it, with four slots cut into the shape just like a regular collet. After that wooden rings would be fit onto the different steps on the outside, but I'm thinking I would just use two pipe ring clamps (the second just to counterbalance the first.) PS - this would obviously be for small stuff - some tops, maybe, and a tiny product I'm looking to mass-produce for a business associate. Thanks in advance! - Jeremy
Re: Wooden collet chuck
John Peck
>Mike Darlow shows some homemade wooden chucks beginning at page 29 of his book "Woodturning Methods". The hose-clip spring chuck held in a scoll chuck at Figure 1.55 might be what you're interested in.
Jeremy in LA
>Thanks John - I'll go check it out! I'm guessing there aren't many surprises, but it's always worth seeing how someone did soemthing. Thanks again!
- Me
Wayne Leach-NW Ontario
>Jeremy,
Does this look like what you saw?? I scanned it from Wood magazine quite a long time ago??
REgards,
Wayne
Phil Joines Krum, Texas
>Dick Sing uses a chuck like that to turn his eggs. I'm not sure if there are instructions for making one in one of his books and I can't get to my copies right now.
>I made a number of these. Several made of a "tube" of wood similar to one in the picture posted above. One was made with the base being an old circular saw blade That had slots cut in it like the spokes in a wheel and a "rim" of wood attached. You can also make them form pieces of plastic and metal pipe.
Let me offer a warning. Be very careful about the pipe clamps. The "screw" extends about the surface. It can give you a serious injury if it hits you. The end of the strap can be even worse specially if it is facing the wrong way. It is a wise idea to make sure the strap faces correctly and there is a grove for the screw clamp to "hide" in. On some of mine, I tape over the strap and on some I put a piece of rubber inner tube over it. Be careful.
Jeremy in LA
>Hey Wayne! This is different from what I saw.. the one I was was tapered in steps, getting smaller towards the tailstock. I may make another based on your picture though! I'm realizing there are many good ways to do this project. Thanks again! - Jeremy
Jeremy in LA
>Lots of ways to skin a cat, I'm learning! Thanks for the safety tip too, Barry. The design in my head more or less allows for hiding of the screw, but I may go a bit further to ensure such, given your warning. Also, I'll work on the stray end as well. Thanks for your input! - Jeremy
It's called a knucklebuster feature
Al Kapocius
