3520 remote
3520 remote
3520 remote
Ed Karch
>Just got a remote switch, has anyone hooked one of these up? two wires white and black.
Re: 3520 remote
Re: 3520 remote
Gil Jones on Lake Seminole GA.
>Ed, ckeck your email, the wiring diagram for PM3520B is on the way, I do not know if the 3520A is any different.
Re: 3520 remote
Re: 3520 remote
Bob Fawcett
>Hi Ed,
I have one on my 3520 and I hooked it up. The instructions are in the manual.
The black wire goes to push/pull switch. Its the terminal that has the white and blue wires on it now. The white wire connects to the white and blue you remove from the push/pull. This puts the remote in series with the push/pull. That way either switch can turn off the lathe, and both must be in the on position to start it.
Here is a link to the manual. The schematic is a poor scan.
http://www.wmhtoolgroup.com/partfiles/Powermatic%20Model%203520A%20Lathe.pdf
If you have questions I will find you an answer.
I don't think the colors matter, just put the remote switch in series with the push/pull.
Re: 3520 remote
Re: 3520 remote
Gerry Meekins
>Ed,
Real simple. Just put it in series with the main on/off switch.
Gerry
Re: 3520 remote
Re: 3520 remote
>Ed, they are different, and the PM3520A Wiring Diagram is in your email too.
Re: 3520 remote
Re: 3520 remote
>I installed one a year and a half ago. last night it stopped working for a while. Took me a few minutes to narrow it down to the switch. It stopped once again this morning. I guess I'll pull it off and clean it out. I wouldn't think it would be that dirty it has a pretty good box. I'll let you know what i find.
Re: 3520 remote
Re: 3520 remote
Ed Karch
>Thanks all, series was what I suspected.
Re: 3520 remote
Re: 3520 remote
Harvey Meyer in Atlanta
>John -
I seem to be experiencing the same thing. Every now and then the lathe won't run. A few raps on the remote switch and all is well again. Doesn't seem like dust could be getting into it. If it gets worse, I was going to take it out of the circuit since I really don't use it much. I'd be interested to know what you find.
Thanks,
Harvey
Re: 3520 remote
Re: 3520 remote
>Harvey It worked well all day today but I think I'll take it apart tomorrow and look. I'll let you know what I see.
Re: 3520 remote
Re: 3520 remote
>Harvey I dismantled the box. I had just a tiny bit of dust. It's sealed with an O ring but I think dust can get in through top of the switch. I didn't go any further than that because mine is running right now. I looks like you would either have to completely dissassemble the switch or toss it and get a new one.
