We value your privacy.
>I have an old windsor chair with one of the spindles split in half. I plan on turning a new one, but can anyone tell me if it is possible to install the new one without taking the chair completely apart?
>Old commercial Windsor? Are we talking a loop back or continuous arm? In most of the designs that I am familiar with, you probably will have to remove the upper portion from the stool portion.
The spindles are usually seated in the seat with a 1/2" or so tenon on the bottom as well as a tenon on the top. If the top tenon is not a through tenon, you may have a slight chance of bending the spindle enough so that the spindle will fit into place. It depends on how flexible the spindle is. Usually if it is dry enough to turn reasonably well, it is too dry to be flexible. My $0.02.
>I was successful once by drilling the upper hole for the spindle 3/8" deeper than the length of the spindle and inserting the top of the spindle and raising it up to insert the bottom. With glue in place it will function perfectly well.
Stan has the right idea. For the past 10 years a LOT of my turning work has been this exact sort of thing for antique dealers. If you make the top tenon short enough so when you insert the bottom tenon all the way, the top will slide in. Just be sure to have enough glue in each hole, the theory being that the glue will hold the spindle quite nicely.
>I had to replace two on a rocker I built. I drilled a hole all the way through the seat and reamed out the hole in the chair back. Set the new spindle in the holes and plugged the hole from the bottom of the seat. I used glue and wedged the tenons for a tight fit. It has held up nicely and no sign of repair. Hope this helps
