14" Ambrosia Maple Hollow Form
Devon Palmer
>Slowly starting to get the shape down, still a few things going on with it (1/3 way up from the bottom, there's a wierd curve change), not sure about the top either. but, this is hollow form #8, about 20 or 30 more and I should have one that looks pretty good.
Done in two pieces, seam is the middle black line. The weight is what'd you'd expect. Satin Poly over Teak Watco oil.
- Devo
Re: 14" Ambrosia Maple Hollow Form
... this time with the picture....
Devon Palmer
Re: ... this time with the picture....
Ron in Drums PA
>Nice! I like it
RevDoug
>Very good looking piece.
Turn 'em round,
Excellent...
Peter Teubel
>I like the shape. Very smooth un-interupted curve from top to base. IMO, the collar is a bit busy. You have two different elements there. Either one alone would perhaps work better. This is NOT a critque, simply my opinion. Perhaps others can comment on it as well.
A little PhotoShop editing here to give you a visual of what I meant:
Re: Excellent...
Gary in Zirconia, NC
>I agree with Peter. Nice form.
Re: Excellent...
eliot
>I agree with Peter: it's a fine vessel, but the lid just doesn't appear as well designed as the rest of the piece.
Keith Tompkins
Re: Excellent...
Keith Tompkins
>Me too. The form is very pleasing, the collar needs work. Check out WAlly's collars. In fact, an ebony collar would make the three burnt lines tie in a bit more; as is, they detract rather than add to the piece. That's just my opinion, of course. Overall, a very well done piece,I think.
Brad Vietje
Re: Excellent...
Brad Vietje
>I'm with the gang here -- a be-u-ti-ful piece, there Devon, but the collar is just a bit busy. I was wondering about the 3 lines, then noticed that you made it in 2 pieces. Pretty darned good figure match, and the slight curve change you note is not obvious in the (excellent) photo. If this is just your 3rd hollow form, we'd better keep an eye on you !
You could try an Ebony collar to relate to the lines, as Keith suggests, but I think for a piece of this size, you'd want a pretty substantial one, and maybe Peter's first option would work well. It would also be the easiest change to try, since you could just put it between centers and nip off the curved opening. I wouldn't like it much with a shorter, flattened collar, which seem to me more appropriate on a smaller, shorter piece.
Now about that cheating by hollowing in two halves... ;-)
Safe spinning,
Brad Vietje
Newbury, VT
