Re: Jet 1236 speed control question
Ron in Drums PA
>Be careful, if you lower the speed by opening the reeves drive too much you can ruin the drive.
It's been over a year since I did this to my 1236 and I don't have the lathe in front of me right now, so if a few things a fuzzy let me know and I'll try and clear thing up when I look at the lathe tonight.
Open up your covers, turn on the lathe and set your speed to the lowest setting. Stop the lathe and take notice where the cogs are in relation to each other. You need at least an 1/8" "bite", any less and you can cause damage the lathe.
Look at the handle's base and you will notice two screws. Loosen them and remove the handle. on the shaft you will notice a "gear". Replace the handle while moving the shaft "up a notch". Replace the screws, turn on the lathe and check the reeves drive to make sure you have no less than an 1/8" bite. Make any adjusts you may need until you get it right. Most likely this is all you will need to do.
Step two (only if you are nuts)
In the headstock under the pulleys you will see another shaft below the spindle, on that shaft you will see a set screw. You can tweak a lower speed by making adjusts here also. Be careful, if you make to much of an adjustment the shaft will hit the pulley, so check the clearance before you turn on the lathe.
I bet doing this will void any warranty.
Good Luck
