clarify pm3520 adapter question
Mike Nelson
>I can't seem to find the answer to this. I want to go from my PM spindle,1 1/4"x8tpi down to a 1"x8tpi. I am trying to set up a vacuum chuck, have everything else ready to go but can't attach face plate. I could order a 1 1/4" face plate, but then couldn't use the ones I have that fit the delta mini lathe. Sorry about earlier post, it is a 1" 8tpi that I want to reduce to not 10tpi. any simpler ideas appreciated. Don't have a 1 1/4x8 tap. Thanks Mike
Re: clarify pm3520 adapter question
Re: clarify pm3520 adapter question *LINK*
Russell L. Babbitt Jr.
>Check the link below. If you are using a vacuum adapter that goes through the headstock this may not work. The adapter must have a thru hole. Check with Craft Supply support before you go this way.
spindle adapter
Bill Stehman
>Mike, 1 1/4 x 8 to 1 x8 @ bestwoods 63.99
bestwoodtools
Rich Egan
>Mike: You will need an air-tight seal between spindle, spindle adapter, and your 1" faceplate. Lots of room for leaks there. You'll also need to drill a hole through the spindle adapter. For the cost of the spindle adapter, you may be able to find a 1-1/4 x8 tap, and you can make all the faceplates you want with less chance for air leak and runout.
I have the same set-up.
Rich
Mike Nelson
>Thanks for the info folks. I went to links and do have to drill hole in adapter, you'd think for that price on a reducer they would drill a hole! Rich, I finaly got a machinist that believed I wanted a 1 1/4x8 tpi reducer, it seems 1 1/4x7 is standard! He said they make em that way so you can't go down to the hardware store and get a reducer. He is semi-retired and said to bring in a peice with threads I need (a couple Nova adapters) and he will make what ever I want for 20 bucks, cash only. Got my bussiness. Mike
Allen Neighbors
>I got my adapters, and they didn't have a through hole. So I put them on my drill press, and drilled them. It's easily drilled. However, the hole is not a morse taper.. :o(
I also drilled and tapped them for 5/16 set screws.
Allen
Chris K in MD
>Mike,
Sounds like you found your solution but for others that may need this. I found the cheapest adaptor is from Penn State Industries, they have limited sizes but they do have a 1-1/4X8 to 1X8 adaptor for $19.99. The machining on my unit is very good and I was happy to save the $45-50 vs any other supplier.
To use with a vaccum, you will need to drill a hole in it but thats easily done with your tailstock and drill chuck. As far as a seal a teflon washer on your spindle should do pretty well and is reccomended to prevent chucks and faceplates from getting stuck on your spindle.
Regards,
Chris
1 1/4 x 8 is used in the oil and gas industries
Phil Joines Krum, Texas
>If you have a welder small face plates can be made from 1 1/4 x 8 nuts (MSC sells them) and large flat washers. MSC also has the tap but, unless you find a deal on them, they go from $75 & up.
1-1/4 x 8 Tap for $43.50 at JTS
Craig Daymon
>There is a series of PM3520 links on the AAW site, one of which takes you to the JTS site for a tap and another for the die. The link for the tap page is:
http://www.jtsmach.com/jtswebshop/Taps_Dies/T060.asp
and for the die ($32.20) is:
http://www.jtsmach.com/jtswebshop/Taps_Dies/T126a.asp
Useful for making wooden faceplates and jigs as well.
-Craig
P.S. I'm gluing (epoxy) a 1-1/4"x8tpi nut onto the back of what will be a doughnut chuck this weekend. I bought 2 five packs of the nuts from McMaster-Carr for about $10 per pack.
Re: 1-1/4 x 8 Tap for $43.50 at JTS
Bob Fawcett
>The nuts will probably not run true, mine did not. Make sure you allow for this. You will need to true up.
Stuart Johnson
>The nuts will probably not seat properly either. You might need to use a spacer.
Bob and Stuart, thanks for the heads up.
Craig Daymon
>I have the spindle spacer (actually a spacer for the PM or maybe JET shaper) if I need it and I'll check them to see if they will run true. Though my construction effort might add error to it being able to run true.
-Craig
Brad Vietje
YA, But...
Brad Vietje
>Mike,
While it seems you've found a great guy to machine things for you, I usually figure that every extra thing between the spindle and the wood will introduce a little bit of error, and in your case, a little air leakage (though that might be trivial).
Instead of using an adaptor, why not just buy a 1-1/4" faceplate ? They cost less than either the adaptor or the tap, and they don't have to be drilled.
When it comes to hangin' onto things big enough to need a 1-1/4" spindle, you probably don't want to use your 1"x 8 mini faceplate(s)with the added weakness and wobble of another threaded junction. A single piece of metal between your wood and the spindle will be more rugged. Just a thought ...
Safe spinning,
Brad Vietje
Newbury, VT
The old 'bait & switch'
Mike Nelson
>Well when I got to the machinist he looked at what I had and decided a jig and a this and a that were needed to make the reducer and it would be 95 dollars! Thanks anyway! I went home and made a face plate from 3/4 mdf. I mounted a piece about 3"dia and cut a hole slightly smaller than outside of threads on spindle, threaded it on almost to end and glued a 6" dia piece w ca glue, made the face slightly concave, glued on 'Form Foam' (this stuff is great about 3/16 thick) I turned on the vac pmp, stuck on a heavy wax can for a test and couldn't get it off with a crowbar even with the leak in the bearing! Simple and cost next to nothing. Thanks all, Mike
Re: The old 'bait & switch'
Gary in Zirconia, NC
>Penn State has them for $20.
