Re: PM 3520A Concern (a little long)
Roland B. Kuehn
>I also have a 3520A with a clicking problem in the headstock area. I am also and engineer and do a lot of maintenance on my own equipment of all kinds. The problem I ultimately diagnosed solved the problem. I know of 4 other people with 3520A's with the same problem and my solution corrected their problem as well. The symptoms were a click, click usually only when I was on the slow speed pulley and at fairly slow speed or when I rotated the spindle by hand. When I originally couln't find the problem I called Powermatic (WHM Tool GRoup) and recieved very good response from them. They sent a local repair man out to my house who with me checked all the things that others have mentioned, belts, alignment, set screws, bearings etc. He even filed (carefully) irregular spots on the pulleys. All to no avail. I wouldn't let him leave without a solution. I then took the lead in the trouble shooting. He maintained that it was every revolution of the spindle but we carefully checked and I proved it was every revolution of the motor shaft. We disassembled the motor and pulley and found the following. On the 3520A the motor shaft is quite long. The motor pulley has a keyway its full length but the motor shaft only has a keyway long enough for half the pulley width under the high speed half of the pulley which is also where the set screws are, so there is no support on the slow speed half of the pulley. Also the fit between the pulley and the shaft is a bit loose (maybe only a thousanth or two and not enough for a shim). So every revolution of the motor the pully clicks (moves) when on the slow speed section since there is no support where the key should be. This a poor design in that the key in the shaft does not cover the entire length of the pulley. When the belt is on the high speed section close to the motor itself the key and set screws support it so it doesn't move. The service man called the factory and had them send me a new motor pulley and belt in hopes that it would fix the problem. They also offered to come back and do the installation if I couldn't do it myself, which of course requires removing the entire spindle to get the belt on. I felt that the new pulley and belt would not solve the basic problem that there was no key under the entire width of the pulley.
So using my engineering knowledge, I concluded the solution is to provide a Key under the slow speed section of the motor pulley that didn't have one even though there was not a keyway in the motor shaft. So I took a peice of brass stock and filed it down so it would fit into the keyway of the slow speed section of the pulley. Actually this would be only a half key as there is no keyway in the shaft in this area. I made a slight taper on the brass key so when I placed it in the pulley keyway I could tap it in to take up any slack and stay in place. It has solved the problem and no more click. Therefore I have not replaced the belt or the pulley. Several other people with the same problem have solved it doing the same thing.
I know that you say that the click is every revolution of the spindle. The service man thought the same thing as did I but when we really checked it, it was every rotation of the motor shaft. There are several ways to check it. 1. rotate the spindle with the belt on the slow speed pulley tightened up good and check the click to the motor rotation. 2. loosen the belt or slide it off the pulleys and see if the click goes away if it does it is probably what I am describing. If not it may be bearings or something else. 3. Again with belt removed or loose run the motor if no click most likely it is the problem I describe. 4. place the belt on the high speed pulley section with tension on the belt, and either rotate by hand or run the motor at slow speed. If the click is not there it is most likely agian the problem I describe.
Good luck! Hope this solves your problem. I would be interested if it does. You can either post it or e-mail me at rkuehn@hargray.com
