ADVERTISE HERE - FREE TRIAL
PM 3520 1 1/4 x8 tpi to 1x10 tpi adapter?
Mike Nelson
>Help, I've got a couple of face plates 1"x10tpi need to adapt to 11/4x8 on PM3520. Any ideas?
Re: PM 3520 1 1/4 x8 tpi to 1x10 tpi adapter?
Allen Neighbors
>Check with Bestwood Tools or Packard.... They both sell adapters. I'm not sure of that particular size.
Allen
Re: Correction!
Allen Neighbors
>Best Wood Tools doesn't have that particular size in stock, but will make one for you. Email or call them for a quote on price. Sales@BestWoodTools.com or Call (931) 788-0429. They're located in Crossville, Tennessee.
Hope this helps.
Allen
Could you ...
Clem Wixted
>...bore out the 1" threaded hole and tap it for 1-1/4?
If you don't have the tooling you could have a machinest friend do it, or a machine shop.
Clem
Bob Fawcett
>Are you sure its 1" 10?
Thats not a common size as far as I know.
Many lathes are 1" 8 and 1" 9 is a standard SAE size.
robo hippy
>One thing about the adapters, they will put your chuck and faceplate about 1 to 1 1/2 inches farther away from the headstock. This isn't a problem with small things, but can cause excess vibration on larger bowls because you are using a longer lever. I used an adapter on mine at first, and then got rid of it, and got different inserts for my chucks, and gave the faceplates away. They make a good raffel item.
robo hippy
>There are some odd size lathe spindles out there especially grizzly and Central machinery. I think 1" 10 is a standard size for some metal lathes. I know that 1"x12 has been used and of course 3/4 x 16.
bob davis
>grizzly
Ralph
>Are you certain? All the older Griz's I've seen were 1x12
Allen Neighbors
>John, my little old Grizzly has 1-8 threads, but it's the only Grizzly I've ever had dealings with. BTW, old griz is enjoying the rest! :o)
Allen
