turning plexiglass
turning plexiglass
turning plexiglass
Ernie Miller
>Has any one turned plexiglass? I need to make a base for a fountian it is actualy a foutian base for a statue I was going to use mahogany and then thought about some plexiglass that I have. I figured I would cut it close to round and then give it a spin. all I have is a live cinter do you think that wil hold it well enough to get a shape to it? kind of an oge shape that will hold some copper or brass tube in place with some holes in it to direct the watter flow. Thanks ernie also how far will I need to sand to get most of the scratches out 500 grit?
Re: turning plexiglass
Bob Fawcett
>I would make a jig to cut the circle with a handheld jigsaw and fire polish the edge.
Steven Antonucci
If I understand this right...
steve antonucci
>You need to have a plexi round with a hole in the middle...
Here's what I'd do.
First, drill your hole. Not sure how thick the plexigls is, but I would take a face plate with a wooden waste block as large as I could and turn a small tenon in the middle to match the hole in the plexiglas. Then, I'd put the plexigas on the small tenon, and put a scrap block on the tailstock to prevent splitting/cracking.
you could mark the cut line with a pen/skew with the lathe off, and bandsaw proud of your mark. Then remount on lathe and true. It will help if your waste block is larger than your finished piece, since it will acts as a backer plate, and it will also help if you don't have a million plastic curlies all over the shop to clean up.
Steve
>Ernie I just turned a small piece of black plexi about 4" round. The backer plate is a good idea if it is thin. I use a sharp spindle or bowl gouge to turn it. You need to find the right speed to get the curls. If you force the cut at all it will chip. Some plexi will work with a scraper but most turn better with cutting tools I think. Try both in the early stages and see what works best for you.
For finishing I sand to 600 grit and then use 4/0 steel wool followed by white automotive rubbing compound and then johnson's paste wax. Heat is your enemy so sand at slow speeds, keep the paper moving and if it clogs up toss it. It's harder to get the melted plexi looking good so take your time and sand it carefully.
Bill Hale / Woodspinner
>Wet sanding will also help keep the temp down.
I believe you will need to go higher than 600--
Bill in Casa Grande,AZ.
Bill Stehman
>Ernie,
My father turned tons of Plexiglas incorporated in ornaments and bowls. Sharp tools light cuts and light sanding.
Those are neat!
Winnemucca Lynn
eaglesc
>Dico makes a plastic buffing/polishing compound.
I use it when I make my plexiglass pens.
the cut marks need to be buffed
>Bill Those are really cool. Where does he get plexiglass in those sizes.?
Bill Stehman
>John,
He had a friend at the local university in the mechanical engineering department. They use the stuff to make prototypes of everything. He would drop off huge pieces of all colors. Dad used to make solid Plexiglas bowls and ornaments but thought they looked store bought then figured out how to use wood with it... CA clouds and melts the stuff. He discovered Melamine Glue dries clear and holds forever to both wood and Plexiglas. It doesn't ever harden so really plugs up a gouge thou.
I helped him cut up one piece 8" thick 3' by 6' and nearly broke our backs. I still have a few big scrapes left. I'm sure you can order it online but might be a bit pricey. I'll post a few pics of his ring bowls using plexiglass and different woods.
How much are you cutting?
Phil Joines Krum, Texas
>If you have to cut a bunch out it may be faster and have less waste to turn a ring and bond it to a thin sheet with MEK. Clear poly resin can be used to form a bead (like in welding). I wet sand to 600 and flame polish with a propane torch.
BTW heating in an oven at 300 degrees for about 15 minutes per 1/4" thickness will soften it like taffy. And it doesn't even smell!
None of the above will work with Lexan.
Heat Polish?
Ernie Miller
>Heat Polish? just a quich hit with the torch untill it shines? I only have one to make and a greenish grey plexi that should make a nice base for a bronze statue it will hold a ring for a foutian when I am done I hope.
Re: Heat Polish?
>It's usually called flame polishing. After sanding to 600 or so set the propane torch to a medium flame and lightly pass it along the surface. Do a 1 or 2 inch piece of scrap first to practice. It's pretty easy.
