Poison Ivy & turning
Lou Ann
>I'm new to your message board, and I need your help. I recently got a real bad case of poison ivy, that I got while attending a turning workshop. (The poison ivy got airborne during clean-up, I guess.)
Has anybody ever had this problem?
Thanks.
Re: Poison Ivy & turning
Re: I feel your itching pain....
JamieDonaldson
>... having recently recovered from a bad case of poison oak. The oils of ivy and oak can be transferred in all manner of ways, including dust and shavings. The hairy vines often remain on harvested wood,and the oils can remain toxic for as much as a year or more. Any exposure for sensative individuals should be treated immediately with rubbing alcohol or some other oil solvent, and a cool shower with good soap will remove the remaining agent.
Ron in Drums PA
>I doctor can give you a shot that will help. DAMHIKT
Bill Grumbine (Kutztown PA)
>Lou Ann, our one daughter has gotten it so bad a couple of times her eyes swelled shut and she could not see. A steroid shot from the doctor fixed her right up.
Bill
RobinCorell
>Silk oak/lacewood can affect some people similar to poison oak.
Robin
Jim
>Yeah, I'm having fun with this fine plant right at the moment. I've got one leg half covered with it at this point. It started out as a half dollar sized spot.
I've read all kinds of home remedies for it. I'm slathering on the calumine lotion to relieve the itching.
One of the best things you can do is to avoid it in the first place. I've read how you can put some "glove in a bottle" on if you suspect you might get into it, or mix ammonia with water (I think it was 1:10) and spray it on you.
Then the next best thing to do is to wash it off immediately with dishwashing detergent in tepid (not hot) water so as not to get the oils so far into your pores.
I've read that bleach, diesel fuel, oatmeal, and baking soda can alleviate the sores, but haven't tried any of it. Well I tried bleach on a small spot last night. I've not looked at it today though.
One guy I worked with got a systemic case of it, and had to get shots to get rid of it. I'm wondering if I need to do that since it's spread and it has been almost 4 weeks...
Arrid Extra Dry
Gary Evans Tallassee, TN
>Hi Lou Ann,
Just read an article the other day regarding the effectiveness of antiperspirants in the treatment of poison ivy rash.
Arrid extra dry is supposed to be less sticky than some of the other products on the market. The spray-on kind is recommended.
Hope this helps.
Gary
Re: Arrid Extra Dry
Lan Brady
>Gary,
Being a person that is quite alergic, I would like to read the article. Where?
Is it preventative application or relief after exposure?
Thanks, Lan
Re: Arrid Extra Dry
>Hi Lan,
This came from a column in the Knoxville News Sentinel a few days ago by a local writer, Sam Venable. I imagine you could contact him by e-mail at knoxnews.com.
As I recall, it was the aerosol antiperspirants that contain the ingredient that counteracts the poison ivy oils. Also, as I recall, it was for topical treatment after exposure. It is supposed to dry up the rash within a couple of days.
Gary
Barbara Gill, Remlik VA
>I am very allergic to poison ivy however if I manage to avoid getting it for about 5-7 years my body will resist one or two exposures.
There is a product called Ivy Dry which helps dry up the rash. If you have scratched the skin raw, it will burn but IMHO it feels good compared to the itch. It also comes in an ointment form but I don't think it works as well.
Lou Ann
>Thanks for all your kind responses.
My poison ivy is about gone, through the magic of drugs.
I realy enjoyed turning green wood and I'm trying to avoid getting again. I guess shots are my best defense.
Could be Rosewood allergy
jim reed @ tallahassee
>Many people are highly allergic to Rosewood and its family members. These include Cocobolo, Tulipwood, and others. The turning wood could have been the source of your problem. I got a bad rash from Cocobolo. Took six weeks of Claritin to get rid of it.
Rob Wallace
Re: Could be Rosewood allergy
Rob Wallace
>It likely is NOT the same response, at least from the same class of compounds!! - Rosewoods (genus Dalbergia) are in the legume family (Family Fabaceae/Leguminosae), whereas Poison Ivy (Toxicodendron radicans) is a member of the cashew family (Family Anacardiaceae) which is known to elicit major adverse reactions (including anaphylaxis) in humans, particularly those that have been previously sensitized. Poison Ivy and related taxa (poison oak, poison sumac) produce oils found throughout all parts of the plant, and when these oils contact the skin, they produce contact dermatitis of the sebaceous and/or sweat glands. Although I am not a physician (nor do I play one on TV!), I am often consulted about this response as a botany professor, and have given talks on this reaction to sporting and other outdoor groups. Agents that will sequester the "insulting" oils present on the skin are helpful such as cornstarch, talcum, etc., however I would strongly urge against using "cures" such as diesel fuel or bleach which could cause far worse damage to the skin than the poison ivy itself. Steroidal topical applications (like hydrocortisone) or steroidal injections will help alleviate the immune response of the dermatitis. Dressings may be necessary in severe cases to absorb exudate and prevent scratching/rubbing which could worsen the overall problem.
Hope this info helps...
(Prof.) Rob Wallace
Iowa State University, Ames Iowa
Re: Arrid Extra Dry
Lan Brady
>Gary,
Thanks, I will try it. That 16" hickory tree cut by Duke Power right of way had better watch out now!
Lan
Lou Ann
>I agree with your view on remedies. The rash and discomfort I can take, but when my both my eyes started to swell shut I went to the ER.
I'm not sure what wood was being used although I'm sure it was local hardwoods being used in the seminar.
Thanks for your info.
Misleading info
>Rosewood allergies are well documented in the literature. Just because plants are not in the same family does not mean that they do not contain allergic compounds. I encourage you to do a little research in this area. The results will astound you.
Re: Misleading info
Jim King
>Any info that anyone has concerning wood allergies I would appreciate getting. We are going to try and isolate the chemical or chemicals that cause the problem.
Please send about an ounce or two of shavings or sawdust from any wood that has given you a reaction to:
Mihaly Czako, Ph.D.
> Senior Research Associate
> The University of South Carolina
> Department of Biological Sciences
> 700 Sumter St.
> Columbia, SC 29208, USA
> czako@biol.sc.edu
> Tel.: (1-803) 777-8928
> Fax: (1-803) 777-4002
Any and all descriptive info would be needed and appreciated.
Thanks, Jim King
