ebonizing solution
bob davis
>mary has put steel wool ina jar of vinegar,nothin has happened after 3 days. what is wrong???
ebonizing solution
bob davis
Re: ebonizing solution
GaryG in MD
>Bob, The solution itself does not turn dark, but it will turn wood dark if the wood has tannin in it. Have fun, Gary
Phil Joines Krum, Texas
>Did she wash the oil out of it? It won't work if there's any left in the wool.
Re: ebonizing solution *LINK*
Wes Bischel
>I washed out the steel wool first to remove any oil from it. Then I followed the instructions on this site. It worked out very nicely in the end.
Good luck,
Wes
http://www.joewoodworker.com/ruststain.htm
Ed Heuslein
>Bob, I'll take Gary's suggestion one step further:
1. Let the steel wool, vinegar mixture set overnight.
2. Saturate your turning with the mixture.
3. If nothing happens in about 1/2 hour, let the turning dry.
4. Saturate your turning with tea. I use about 6 tea bags in a 1/2 gallon of water - sun steeped.
Your turning should now be turning dark gray to light black. You can alternate the tea and steel/vinegar mixtures until you get maximum darkness - usually about 3 rotations.
The wood must have tannin in it for the steel wool/vinegar mixture to work. That's why your high tannin woods, such as walnut and oak, work so well. Others can be helped by using the tea soak method.
Good luck. Ed
>Bob That's why I use India Ink. The ebonizing solution varies a great deal with the wood species and how much Tanin it has in it. If you want something less than black then it works great and sometimes turns wood very black. The india Ink on the other hand always turns the wood black.
Re: ebonizing solution'..thanks
bob davis
>mary and i appreciate the responses to our problem,thank u very much...!
