Functional Flower Vase Ideas ?
Brad Vietje
Brad Vietje
>Hi Folks,
I've been asked to turn a functional wooden flower vase, but larger than can be accomodated with the small glass tubes sold in the major catalogs -- probably 12 - 14". Usually I take the position that finished wood turnings (or at least, wood finishes) and water don't mix, but I think I can pull this off.
My ideas so far are to turn the vase out of Butternut (soft, but stable and forgiving), leaving a cylinder inside to accept a removable 2" copper pipe with end cap soldered on the bottom. I may flare the pipe a bit on the lathe up at the top end. I plan to use West System epoxy on the inside to seal out the inevitable drips and condensation, and multiple coats of spar varnish on the outside. This means a glossier finish than usual for me, but I don't know of a better war to get the water resistance I need. In use, the copper cylinder would be lifted out to arrange the flowers, change the water, etc... though I know the recipient of the gift will probably still pour water into the assembled vase, regardless of my instructions.
Does anyone have any better ideas or plans ? I'm all ears...
Thank you kindly,
Brad Vietje
Newbury, VT
Re: Functional Flower Vase Ideas ?
Bill Grumbine (Kutztown PA)
>Hi Brad
With a couple of coats of epoxy, I don't even think you would need to mess with the copper pipe, unless the water they are going to use has a high content of acid in it.
Bill
second that,
>epoxy will be kinder on the flowers, copper is toxic and also the lead in the solder.
GaryG in MD
>Brad,
Sounds like you ought to be able to go to the Dollar Store and find an inexpensive glass or plastic water tumbler that would fit right in there.
Let's see it when you're done.
Gary
Ian
>brad, I've worked with west epoxy for years, boats sit in water for 6 to 9 months of the year without any seepage, and have even made a few built in water tanks out of plywood epoxy coated on the inside, no leakage the copper will react with some of the flowers and cause them to die faster, in my opinion.
IAN
Brian Simmons, Heflin, AL
>You could try a tube made from black ABS plastic pipe available at box stores. You will have to turn down a plug to be glued inside. I have done this and it works. The problem I see with epoxy is complete coverage, if you miss a tiny spot or it is thin and flakes off later you could have a mess. Good luck
My $.02.,,,,,,,,,,,,,,
Richard Jones
>Water only would be no problem, but flower preservative (like the little packet that you sometimes receive with fresh flowers) is mostly a bleach and detergent product. Not sure how that would do with epoxy.
Rich
Brad Vietje
Thanks Everyone ! I may try PVC Pipe...
Brad Vietje
