We value your privacy.
Looking for experience on out board turning rests.
Bert Workman
>I've got my Jet 1642 turning out some nice saw dust a couple of times a week but I want to do some larger, platter type stuff. The head stock will slide right down to the end of the bed so I'll have more clearance than I can ever imagine using. What I need help with is a tool rest for when I'm outboar/overboard.
Are there stand alone rests available? Would I be better off with somehting attached to the lathe to add stability? Anybody been down this road that wan't to warn me of any touble spots?
Thanks,
Bert (the overly ambitious)
Re: Looking for experience on out board turning rests.
Brad Vietje
>Hey Bert, (...hard to do that w/out the Ernie accent...)
An outboard stand bolted to the lathe and attached to the floor will be much more stable than an independent floor stand. Some people have adapted the outboard stand from a Vicmarc VL-200 for use on Jet and Powermatic lathes -- I have not done this yet (3520-B), but probably will.
I used an old heavy Oliver stand enough to like it, but it could still tip into the work when roughing, which can be dangerous. I got used to standing on the outermost foot. I also used a Delta stand just long enough to confirm that its just as unsafe as it looks. Powermatic makes one with additional weight on the outside leg for extra stability, but I have never used that one.
If you search for the Vicmarc stand, you may find photos of it mounted on the Jet 1642 -- seems like the best way to go.
Safe spinning,
Brad Vietje
Newbury, VT
>This pic was posted on the AAW site by someone using the name Dfriedel, from NJ (?). Gary Ljostad also wrote that he uses it on a Powermatic 3520 w/out problems(and his excellent work shows NO problems !).
Bill Grumbine (Kutztown PA)
>Hi Bert
I have used both types of tool rest, and the free standing ones are scary at best. The ones which are bolted to the lathe are going to have vibration in them no matter how big and strong they are. My Poolewood has a 3" square steel tube, and it vibrates if I do not put the foot down. I do get very good results with the rest when it is both attached to the lathe and resting solidly on the floor. Good luck with your project.
Bill
David Galloway
>I have used the Vicmark as posted previously on my PM3520 and it is excellent. I use it with large bowls and it mimics the work on the VB Bowl lathe. It is relatively inexpensive and is SO much better than the stand, any stand, as it is an accident waiting to happen.
Karl in IA
>Have you considered adding the Jet bed extension, but bolting it onto the legs in a lower position. I think the PM 3520B has holes drilled lower for just this use.
