Any Secret to Removing Insert from Chuck?
Charlie Anderson
>I'm changing the insert from a 1" to a 1 1/4" but the current insert seems to be firmly, after 2 years, in place.
Any ideas?
I would just use a spindle adapter but I'm worried about runout although for $60 the adapter should be pretty true.
Re: Any Secret to Removing Insert from Chuck?
Stuart Johnson
>Did you remember to remove the set screws? Other than that, you might clamp the jaws down on something and using a big wrench.
Ric Taylor
Ric Taylor
>The screws on the adapter should push it right out.
Ric
If it's a Oneway
Bill Howatt
>Remove the screws holding the adapter to the chuck. Put 2 of them in the threaded holes and evenly tighten them; they will push the tapered adapter out of the chuck body.
Bill
Brad Vietje
What kind of chuck, Charlie ?
Brad Vietje
Re: What kind of chuck, Charlie ?
Charlie Anderson
>No set screws.
It's a SuperNova.
Thanks everybody
Charlie Anderson
>A little PB Blaster and brute force did it.
>Charlie, I have the Supernova too, it has between the two big holes to open and close the jaws, two smaller holes, about 6mm and one of them is a dud, tthe other has a set screw there, you will need a 3 mm hex wrench, loosen it, lock the spindle and remove the chuck, then you will need an adjustable wrench to remove the adapter.
Jorge
Carole Valentine
>Charlie, you should definitely have at least one set screw. If you don't, you are lucky the insert didn't unwind on you! It's hard to see down in that hole.
A friend of mine always says...
Gary Evans Tallassee, TN
>brute force and ignorance properly applied can do anything.
Gary
