Re: DIRTY ONEWAY HELP!
Fog Tanner
>When I got my Delta, I put two coats of car wax on the whole thing, the bed and all the painted surfaces. When I got my Vic 300, same thing, I waxed everthing that I could reach. That got rid of the problem you have encountered. I was given that tip by someone who had the same problem as you - same lathe.
Since you will have to strip and repaint, you might think about some of the "Grafitti Paint". I was looking for some new paints for my raceplane and came across a paint made for school buses. Our raceplanes always had a stream of oil going down the side of the plane from the 2 cycle fuel (oil, nitro, and methonal). This paint was impervious to the oil. You can spray it with any other paint and it will either run off or you can wipe it off with a rag - the grafitti that is. Basicly no paint will stick to it, the only problem is it will not adhere to itself so there is no such thing as a minor touchup. Not sure of the color choice, as I didn't go anyfarther since there is always that ding on landings.
You can always repaint your lathe with one of the automotive paints, I use Deltron and use a clear like Deltron Clear which is impervious to your normal finishes. Alcohol will not phase it, I use 95% to clean the plane up - and nitromethane will not strip it. You can also get some pretty cool colors, just depends on your pocket book.....
