Re: New Glaser Tools???
Rick Allen
>The new and improved Glazer tools seamed fine. The edge was sharpened wrong on the bowl gouges but that won't take long to put right. I was unaware that the glaser tool unscrewed from the handle. I know the CryroSteel tools have blades which unscrew from the handles. You can use any length handle you like on any of their blades.
They changed the size of the Glazer handle. It is slightly bigger around and the "no-roll" shape is slightly different. The red color is also slightly different. The but end is a screw in plug. In the handle is a plastic tube of lead shot. You can remove the tube and "adjust" the amount of lead shot in the handle. The flute is the same length as before but the tool is longer out of the handle. The length of the handle appears longer.
The price they sold for at the booth was $159.95 for the 5/8" (1/2" English measure) "oval" (which is the shape the older Glazer tools are) bowl gouge. They also have a "U" shaped bowl gouge which cost a little more but after looking at it the flute was shorter and you would need to grind back a good portion of the tip to get the shape I am accustom to. That $159.95 price is up $25 from the previous price. All the tools appeared to be A11 steel. All the Glazer tool handles are red. They indicated that they would continue to make V15 tools but that the handles for them would also be red.
They had no plans on selling the tools at the show. When I first talked with them none of the tools were for sale except for some "Bonnie Kline" sets for $1200 (no that isn't an extra zero). By the third day they were selling the tools and had made up a pricing schedule.
BTW Jerry has been cryro treating his tools for 10+ years.
The new CryroSteel tools were different. All of these tools have the same internal shank. That lets you switch handles at will. Jerry had a travel set of tools and handle which I never saw. Perhaps this is a take on that. The CryroSteel tools have lead shot in the tool steel as well as in the handle. You can get to the lead and "adjust" the amount in the handle as well as the tool. The scrapers I saw had stainless steel shafts with a thick layer of a harder steel over the stainless. Good in theory I suppose. But the tools were not available to try so I could say how well or poorly the design worked.
Several of the demonstrators used a 3/8" (1/4" English measure) bowl gouge at their booth. The tool had an unusual shape there was a LOT more steel above the flute. The claim was that to tool will be stiffer so you can use tools with smaller cutting edges and have the stiffness of a much larger tool. The business part of the tool was at the bottom of the shaft. Imagine an offset turning where a 3/8" rod is center on the bottom of a 3/4" rod so that the bottom of both the 3/8" part and the 3/4" part are a straight line. Now cut back the sides of the 3/4" rod to 1/2" centering the 3/8" part. Looks kind of like and "h" (the top part of the "h" is longer and the bottom part of the "h" is shorter. The handles for the CryroSteel tools are light blue. They are more round than Jerry's handles but still non-roll. The ridges on the handles go from one end to the other, unlike Jerry's handles which hove the two round portions.
If you like the previous styled Glazer tools you will like the "new" Glazer tools. I have no idea on the pricing for the new CryroSteel tools.
The new Glazer tools should be available in 6 to 10 weeks (I think that's what they said). They had no "deals" with anyone such as Craft Supplies on Wednesday as to price or availability. I spoke with the folks at Craft Supplies on Wednesday and that is what they said. A member of the woodturning club I belong to would like to sell the Glazer tools. She was told that would be great. She asked for price lists and was unable to get a price list.
I bout two of the 5/8" Glaser bowl gouges at the end of the show. They were happy to laser engrave my name on the handle (in the round area) which I thought was a nice touch.
