beal buffing question
jared
>Hello: I just got a beal buffing setup. I have several bowls that have two coats of well cured, about two months, waterlox. Is that a deep ennough finish to get good results with when buffing? The rest of the story is that I put the two coats of finish on, fully intending to put a couple more coats on, but then got distracted by my work, ie spring planting. I now have a lady that wants some bowls and I dont want to sand, apply more finish and then wait for it to fully cure before applying the buffs. What do you think? THanks in advance Jared
Re: beal buffing question
Kevin Gerstenecker
>That finish should be fine, and take a nice buffing. I have buffed many turnings with just one coat of Danish Oil and the results have been very good. You can also buff bare wood with outstanding results. Often times I will use no finish on lighter colored woods to preserve the natural color, and simply buff them. Some people think you are full of beans when they find out those items have no finish other than the buffing compounds and wax! :-)
Ric Taylor
Ric Taylor
>Jared,
I use Waterlox and the beal buffing system also. Two coats of Waterlox is all you need for a smooth, high-gloss finish. Once in awhile I'll put on three coats, but it's not really necessary.
Here's what I do: Put on the first coat heavily and let it soak into the wood for about 5 minutes, then wipe the wood completely dry with paper towels. 24 hours later, I'll go over the wood lightly with 0000 steel wool, or 600 sandpaper, then put on another coat of Waterlox and wipe it dry again. Six hours later, you can go ahead and buff, or do another steel wool or sandpaper exercise, with one more coat of oil wiped dry. If you put on a third coat, you can buff after six hours, but I usually wait until the next day.
In most cases, two coats of Waterlox and the beal buffing system is all you need for a great-looking finish (and I'm pretty picky about my finish). On tight-grained wood, three coats of Waterlox and the beale system can give you a finish that looks like glass.
Many people say it is necessary to wait a long time before buffing, like several weeks, but that is not necessary at all with Waterlox, it cures very rapidly. You can easily complete the finishing process on a project during a weekend, with a finish that lasts.
Ric
Carole Valentine
>Jared,
You will be fine to buff. I do not, however, agree with Ric about 6 hours being sufficient time for Waterlox to cure (note I said cure vs dry to touch) even when applied in wiped dry coats. Maybe in the desert, but not here in humid Eastern VA!
Richard Allen
Richard Allen
>As the others have said 2 coats should be fine.
**** Warning!! Warning!! Warning!! ****
The first several times that you use the Beal Buffing system you will have an explosion of fibers coming off the buffs. This will likely not hurt your finish or your abality to buff the finish but it will put a LOT of fiber in the air, which is not likely good to inhale. The tripoli and white diamond are also to be avoided when breathing.
Use dust colection and a resperator when buffing, especialy the first few times!!
In a few months you will wonder how you ever got along without the buffs.
Ric Taylor
Ric Taylor
>I live in Houston, one of the most humid places in the country. My pieces with Waterlox buff perfectly after the first coat has dried for 24 hours, and the second coat has dried for at least 6 hours. Another 6 hours if there are three coats.
In actuality, it usually works out that my final coat dries overnight.
It works great, and I get a glass-smooth finish that lasts forever, even in this high-humidity area.
Here is a great article on Waterlox by another woodturner in a high-humidity area:
http://gulfcoastwoodturners.org/RESOURCES/Waterlox.pdf
Ric
