aligning a craftsman monotube lathe
bernie feinerman
>The headstock and tailstock of my Craftsman 2" monotube lathe no longer meet. Misalignment error seems to be 3/16" or greater.
How can I fix the problem?
bernie feinerman
Re: aligning a craftsman monotube lathe
Roger
>Is the alignment off vertically or horizontally? If it is off horizontally, loosen big screw head at tail stock end of tube several turns.On the rear of the head stock where the tube goes into the headstock you should find a setscrew with a locking nut. Loosen the locking nut and the set screw slightly and this should allow you to rotate the tube in the head and tailstocks. Put a pointed center in both head and tailstock, slide tailstock up to headstock and rotate tube to align points. Tighten everything down and recheck the points, adjust if necessary. If alignment is off vertically, you may have some wear or a bent tube. Don't know of a way to align points vertically, sorry. Good luck.
Roger
Curt Fuller
>I turned for a few years on a Ridgid 1200WL that is essentially the same lathe and had problems keeping the centers aligned also. There's a brass screw on the back side of the tail stock that is for making minor adjustments to the alignment. But 3/16" sounds like either the the entire tube has turned or the spline that is riveted to the bottom of the tube for the purpose of aligning the tailstock has become loose. I eventually had to drill and tap holes through the spline and tube for machine screws every couple inches to keep the spline from moving. The tube lathes were made for spindle work and there is too much leverage against the toolrest when turning bowls and odd shaped things. That riveted spline just won't hold up to the beating.
bernie feinerman
>Thanks for your good suggestions. The misalignment seems
only horizontal (so far).
Packard has a Morse Taper alignment tool (both #1 & #2)
which I will order before I do any serious lathe realignments
The Tailstock has a locking set screw but adjusting it does
not seem to do much of anything.
I did not find any setscrews holding anything (other than the
belt guard) at the headstock end of my lathe.
I will loosen the tailstock end of the monotube mount
and see if the monotube can be rotated.
tek-Brunswick, Ohio
>Look all around the headstock where the tube comes in. There should be a set screw. I had one on mine. I moved on to a better lathe and gave Monotube to a friend. The tube can be rotated in the head and then locked down.
Tom
bernie feinerman
>Turns out there is a locking set screw in the bottom of the headstock to secure the monotube. I had the lathe bolted to a solid wooden topped bench. Once the lathe was dismounted from the bench, the set screw is obvious.
Thank you for your suggestions.
Drill a hole?
Bob Fawcett
>You might want to drill a hole in the bench for access later.
