Making punky wood usable?
Steven Antonucci
steve antonucci
>I know that I've read some tips for making punky wood more suitable for turning in the past on WoodCentral. I have some spalted maple that I'm trying to save, and I'd like to make it harded to cut without changing colors or having issues finishing later.
What my best bet? 50/50 glue, commercial product, or some other homebrew?
Steve
Re: Making punky wood usable?
Russ Fairfield
>You left out buying CA glue by the quart.
Steven Antonucci
Just the thought of my eyes burning...
steve antonucci
>makes me not want to consider it. It's a lot of wood to cover...
Steve
Ric Taylor
Ric Taylor
>Steve,
Minwax makes a wood hardener that works well. It's in a yellow can at Home Depot and Lowes. Be very careful with it, it is VERY flamable. Don't use it around any ignition sources, don't even use power tools around it unless it had thoroughly dried (because of sparks in the power tools). Just slop it on, and it soaks deeply into punky wood and dries pretty quickly.
You can also use thinned lacquer, which will soak into the wood and stiffen the fibers.
Ric
W.C. Turner
>I've heard of a product, called Polyall(SP?) 2000, that Herm, over on WOW recommends. Says it's very good for this.
W.C.
Rick Davenport
>Are you thinking of polycryl?
It's in the Craft Supplies catalog.
Never used it though.
Rick
Wally Dickerman in Arizona
>Unless you are trying to save some exceptional wood I suggest that you toss it. Life is too short and wood is too plentiful to waste time and effort on crappy wood.
I have successfully saved some very nice wood by using the 50/50 white glue method. After rough turning as best I can with difficult wood, I've soaked the piece in the glue/water solution for about 24 hours. Longer might be better but I haven't tried it. The soft, punky areas will soak up a lot of the solution so it needs to be set aside to dry for a while. It will warp, so allow for that when rough turning.
Wally
W.C. Turner
>Wally: <<<"Life is too short and wood is too plentiful to waste time and effort on crappy wood">>> I heard John Jordan say the same thing! I agree.
Rick: <<<"Are you thinking of polycryl?">>> No
*****!!!! I Use Waterlox !!!!*****
Blake Washburn
