Dimensions for a cremation Urn?
Roger Dunn
Roger Dunn
>I need to turn an urn for a cancer patient. What are the dimensions - generally? and how do you figure the volume for a cylinder to hold ashes? Is it Pi x r squared x height?
Thanks
Roger Dunn
Re: Dimensions for a cremation Urn?
Bob Fawcett
>Greg Jenson did a demo on this at TDs gathering. I think he said the volume of a gallon of milk. If that is incorrect, someone will correct me. He measured with sand or something similar. The dimensions will be dictated by your block of wood.
right
TDaniel
>216 cubic inches average or 1 cubic inch per pound of weight; it doesn't have to be exact. Greg is at L'Ville this week.
TD
Re: right
Jerry Whitaker
>Hopefully someone will be able to tell us how many are in attendance.
Keith Newton
>Your math formula is correct, and a gallon is 231 cubic inches.
However, I have a stainless cylinder which is used for this purpose, and it is 5 3/4" x 7 3/4" which only comes to about 200 cubic inches.
Roger Dunn
Roger Dunn
>Thanks to all! I wish I didn't have to make the inquiry.
>Roger,
Without reading the other messages, in the past this subject has come up and there was a post, I don't remember who posted it, that recommended 1 cubic inch per pound of weight of the person; during the recent gathering at TD's, Greg Jensen recommends 1 gallon.
Hope this helps
Jorge
Keith Newton
>Uhmmm. Yea, Times like this can be hard. I just thought I would add this to give you a little more freedom of form.
To figure the area of a sphere, if my memory serves me correctly, is 4/3 Pi X Radius cubed. Or somewhere around 7 3/4" diameter for a one gallon sphere.
And to take this a little further, if you wanted to flatten that a little, it could be 10" diameter inside and about 4.4" high
Roger Dunn
Thanks Keith!
Roger Dunn
Roger Dunn
thanks Jorge.
Roger Dunn
Russ Fairfield
>My only advice is to think BIG. After allowing for wall thickness, one (1) gallon is a big pot. And, always allow for some extra room because the worst thing that can happen is to have a little left over after filling the urn.
1 gallon works because it is 231 cubic inches, or 231 pounds of living person. I like the volume measure because I can fill the finished urn with rice or similar and measure it with a graduated cup.
Roger Dunn
thanks russ.
Roger Dunn
