electricity and a compressor
e
e
Re: electricity and a compressor
e
e
e
e
Re: Is this a stealth gloat?
Keith Newton
>Since I can not see any text, I am just guessing that you may be having a problem getting this thing going. If so, I think the problem may be that you can't get 220 V through 2 half breakers, because they are both hooked up to only one 120 v leg in the panel box.
You will have to use a regular 220 breaker, or maybe transfer some other wires to the one that you have it hooked up to, and move these over to two of the others which are side by side. Most will have a little hole through the toggle which will allow you to run a little wire through the switch arm so that they both throw if either one heats up the other one gets tripped also.
pictures for the chat ..
e
>sorry ... posted this for the chat
wired everything up, but the breakers i got from hd didn't work...
these are zinsco breakers and apparently i need the THIN model.
...and yes, this is a gloat on my fused disconnect ...
Re: pictures for the chat ..
Keith Newton
>E, I think you may have misunderstood. I don't think you can use the thin for 220. both sides are hooked to the same hot leg, and you need two for 220. Although, that panel box doesn't look like any that I have worked in, and I can't see the bars that the breakers stab onto.
Have you put a tester on the wires out to ground to verify that you are not getting power out?
e
>thanks keith ...
in one of the pictures, the last breaker in the box is the 220v/20a breaker .. it is the breaker for my lathe...been hooked up for 6 years. Yardbirds used to sell them however they've been bought up and closed by Home Depot(hd) :>(
hd does carry zinsco breakers but they are a grey, thicker version. i've tried two of them and neither one worked and they don't snap well onto the two bars in the panel as the others do.
i temporarily hooked up the compressor 10/2 romex lines to the lathes breaker and everything works great. therefore, i've concluded that i need a breaker of that style (which i believe is the 'thin' version), only a 220/30a.
H/D doesn't carry the thin version in store, but only on-line ...so i'll wait to see if it is like my lathe breaker.
Bill Hale / Woodspinner
>Considering the look of this box I would put in a total new sub panel.
First it does not look as there is a main breaker in the box. The main breaker protects the wire from your power source to this box and alows turning off the panel. Check the wire size from the source and size the sub main breaker to that size. If you have questions ask here for help. If you don't know wire size cut off a small piece and take to an electrical store for size info.
New boxes are cheap and safer than what you have. Buy a panel where you don't have to use twin breakers. I have not had the best of luck with them.
Bill in Casa Grande, AZ.
main is 200 amp on the far right
e
>but yes, i dream of a new service panel ... hopefully, after i win the lottery this dream will come through.
oh, forgot ... you have to PLAY the lottery... better go find my dollar :>)
Re: 200 amp ?
Ed in Leaside (Toronto, Ontario)
>From what I can see in your pic the breaker is rated at 100 A?
Ace Foster in Port Orchard
>Don't know if it helps any, but the Ace Hardware store in Ben Lomond (Santa Cruz Co.) where I used to work carried Zinsco breakers. Maybe the one in your neighborhood does, too. Pricey little rigs, tho'.
Ace
main is 100 amp on the far right
e
>hope my nimble mind is brighter than my nimble fingers
