I just burned my electric chainsaw! :-(
Ronny Eelen (Belgium)
>When a chainsaw starts flashing, smoking and giving light..... it's burned, or is it joking on me?
Ronny
Ronny
Re: I just burned my electric chainsaw! :-(
Thad
>A swift plunge into water usually corrects this quickly...however I've never personally tried this with and electric chainsaw...you'd better be really fast, or perhaps upgrade to a better saw.
Ray
>If you caught the smoke in a bag and then put it back in it will be O.K.
Roger
>It's gearing up for the 4th.
Gil Jones on Lake Seminole GA.
>Hi Ronney,
If it has brushes, they my need to be replaced.
Lan Brady
>You got an early warning. Mine just went pop and shorted everthing that was on the same circuit!
I replaced it with gas and do all my cutting outside now!
Lan
Ditto!
Gary Evans Tallassee, TN
>I agree with Gil,
A bad set of brushes can produce lots of fireworks.
Check the brushes before you chalk it up as a total loss. Also be sure to clean up the end of the armature with sandpaper and scrape the slots between the segments of the armature where the brushes ride. You may find that you have a brand new electric motor.
Just cause you let some of the smoke out doesn't mean you let ALL the smoke out. 8^]
Gary
>thanks for the replies, funny and useful... will have someone check it out for me.....
or I might get a new gas eating machine, no extension cord, more power, longer blade, sharper chain, more noise, that scary noise... ripping sound... screaming.... bits flying away....... when is the next Friday the 13th...?!
tm
>before plunging into water unplug first
tm
Pete in Holland, MI
>How heavy of extension cord were you using? Light gauge extension cords are often the reason for pre-mature death of a power tool.
