Pinnacle Tools at Woodcaft?
Roger Dunn
Roger Dunn
>A search turned up zip for comments about this line. Has anyone bought and used them and what is your opinion of their quality?
Thanks
Roger Dunn
Re: Pinnacle Tools at Woodcaft?
Russ Fairfield
>I have used them at the local Woodcraft store for classes. They seem to be OK. They grind to just as sharp an edge and seem to last as long as a good M2 tools steel such as a Sorby. My only complaint has been the handles on the spindle gouges being longer than the other brands and longer than what I am used to using. The longer handle changes the balance of the tools and how I have to hold it; and that makes it awkward for me to use. Other than that personal thing with the handles, they are a good tool for the money.
Others may have different opinions.
Wilford Bickel
>I compared the length of usable steel to other higher priced brands when I was in the store recently. While your initial cost may be lower they put a short length of usable steel in these tools and you will have to replace them much sooner than a Sorby, Crown or Henry Taylor. Ultimately your final cost will be cheaper going with the other brands of tools based on usable steel and repurchase.
Rick Davenport
>I have a 3/8" bowl gouge ground especially for the bottom of bowls.
It works fine and stays sharp as long as my Sorbies.
The longer handle works great for me.
Rick
Earl Kennedy
>I have a 1/4" bowl gouge and a 3/4" skew.I shortened both handles.They are much handier this way.You don't need long handles on these 2 tools.I like both very much.They shoud last a long time and be better tool as they get shorter because of less vibration.I have not tried any heaver tools but may buy the widest skew they have.I took the steel out of the handle of the skew and just chucked the ferrel up in the chuck and turned the handle down to suit me.The gouge I just stuck the steel in the head stock and gripped the ferrel and turned it down.
Roger Dunn
Thanks for your input!
Roger Dunn
TheHeretic
>I have a 3/8 bowl gouge. I do like it but like others have been saying the handle is to long in comparison to the other tools. Now on some I might not be worry some but I only turn on a Jet Mini lathe and they do and are cumbersome at times.
Sharpening them seems to be as good as the Sorby tools as well.
Dean
Columbus OH
Buy Individual ones...
Peter Teubel
>...not a set. Compare the bowl gouge in the set to the one sold individually. The one in the set is an inch or so SHORTER in flute length. Looks like the mfg ground them down just to fit in the box.
Other than that, they work fine. Personally, I don't like their flute design. Its more of a v-flute like a Glaser rather than a parabolic (which I prefer) shape like a Crown or Sorby.
Re: Usable Tool Length?
>I compared the length of the usable steel in several Pinnacle tools to the equivalent Sorby tools, and could find no appreciable differences.
