Turning a Plinth sort of
Tony - Memphis
>I'm trying to turn a base for a glass globe to hang a pocket watch in. Seems simple enough, but I sure am having a heck of a time with it. I know I've turned something like this before for a vase type thing, but I just can't seem to get it right. This is similar to a platter I guess. Anyway, thanks for any tips. I started off with a piece of bunbinga which is hard as rock, so that probably didn't help. The mahogany went a little easier.
Tony
Re: Turning a Plinth sort of
Brad Vietje
Brad Vietje
>Tony,
If you are mounting a piece on a faceplate, (or a chuck, glue block, etc ...) in typical side-grain orientation, treat it like the outside of a side-grain bowl -- that is, cut the profile from smaller diameter to larger to cut with the grain. Assuming your base will be widest at the bottom, and curve upwards to a smaller diameter at the top, this would be cutting from top to base.
Even so, Bubinga can be pretty tough wood ! Sharpen, hone, go lightly -- good luck !
Safe spinning,
Brad Vietje
Newbury, VT
Thanks
Tony - Memphis
>I wondered if maybe the bubinga was a bit too hard for a pre-rookie like myself. One problem I had was trying to turn the piece like you would a spindle (and I'm not too spiffy turning those either!). I quickly learned that is a no-no.
Thanks for the help.
Tony
Re: Thanks
Bob Fawcett
>What tools are you using?
Re: Thanks
Tony - Memphis
>I have a 3/8" bowl gouge. Its a Sorby. I sharpened it on my Tormek. I think the grind on it it pretty close to what came on it. I probably changed it a hair.
Tony
