TAPPERED HOLE
mn2tx
>How do I drill a tapered hole in a 2" thick block of wood. Taper should be about 5/8" at the bottom and about 1"at the top.
Any suggestions??
TAPPERED HOLE
mn2tx
Any suggestions??
Re: TAPPERED HOLE
Phil Joines Krum, Texas
>If you can mount it on a lathe, drill the hole with a 5/8" bit then taper it with a scraper. Mark the 1" circle first.
Re: TAPERED HOLE
>You have posted this on the Turing Board. That suggests you have a lathe. Why not chuck the block and turn the hole?
OK, OK, you asked how to drill it. I had to do two such holes. What I did was take a paddle (spade) bit and grind it down to a taper on the sides and drill them. I used a very fine point black Sharpie to draw lines to grind to. It worked fairly well. I suppose you could make up a grinding jig to guide you.
You might be able to buy a reamer or broach(?) to do this. If you can find one the correct size you could drill the smaller hole and then ream it.
Re: Same method that Rude....
JamieDonaldson
>.......used to drill his candlesticks-custom grind an old spade drill bit and stick it in the drill press.
Re: Sounds like a chair leg tenon..
>what I do is drill a hole (5/8" or less) at the appropriate angle. I then use a tapered reamer in a drill. If you want to do it "by hand" - drill the hole and use a tapered reamer that you build (cut a slot in a tapered piece of hardwood and put a keyhole saw blade in it). If you want a source for the reamer, I've got one.
>In John Alexander's book on making green wood chairs there is a tapered reamer that you make on the lathe. It uses a keyhole saw blade that you can get at the hardware store. I've made 2 of them for my classes. They are really easy to make. I don't know if the reamer is in his first book but I've heard that it is included in the latest one. I got the idea from an article he wrote in one of the magazines. The nice thing about this reamer is you can make it any size and taper you want. Of course the easiest thing is to make the reamer first and then turn your tenon to match. I drilled a reamed a hole in a scrap block and then cut this block in half. This gives you a test hole to fit over the tenon to make sure you have sized it properly. If you want I will photograph the tool tonight when I get home. I may even be able to find the tenon test piece but who knows what box that ended up in when I moved.
Re: and it's online... *LINK*
Mike Hamilton
http://www.greenwoodworking.com/reamer.htm
Your good Mike, and quick :).
Re: Sounds like a chair leg tenon.. *LINK*
>One of the tapered reamers that I have is in the link below. I usually use it with one of the beefier hand drills.
Tapered reamer
Re: reamer plans... *LINK*
Keith I - East Tn
>This is the home made reamer I think you are refering to JL. It is easy to make and works great.
Keith
Reamer Plans
Re: TAPPERED HOLE
mn2tx
>Thanks for the replies.
"John Alexander" home made is the way I will go.
Spade bitts are too short..
Spinning wheel is the porject.
I can not turn the tapers on the lathe as they are at the end of a large block.
Three of the holes don't go through so I have to have a specfic size.
I am not that far yet but eventually I will let you all know what kind of results I got.
