What kind of bits do you have?
Phil Joines Krum, Texas
>Most bits can be fitted with an extension. I wouldn't use a spade they vibrate.
The 1� Silver $ Deming bits with a 1/2� shank work well. An extension can be made using some 1/2� drill rod and a motor shaft coupler. The 1/2" entension tends to run straiter.
This is what I use but I make them 18" long. You need a 1/2" capacity drill chuck to use it.
Enco part #�s
17/32 to 1� 5 bit set, $11.35 301-0205 (cheaper than just the 1� at most places)
1/2� ID 1�OD shaft coupler, $6.45 891-6317 (you can turn the outside down on the lathe or grinder for more clearance if you want)
1/2� x 3� drill rod, O1, $6.18 408-0029 (use the extra to make some tools)
Or you can get a 1"x 12" Aircraft drill for about $100
