THE WOODRAT IS BACK!
bark inclusion
bark inclusion
bark inclusion
GaryG in MD
>I got rid of the remains of a dogwood today. It died from borers, I think, and I've been chopping it down and saving a few pieces and recycling the rest. I really like the fine, satiny surface of polished dogwood, and the beautiful, rich brown color that it finishes into with Watco Danish.
I saved a branch junction and chain sawed it in half down the "Y" axis. Unfortunately, instead of a nice flame pattern, I found a bark inclusion. (Yeah, I know, it's a real dog.)
The inclusion is quite linear and relatively narrow with a constant width, and it goes just about all the way across the billets. I have two questions, one artistic and one technical:
1) Should I save it or toss it? I would like to see examples of small bowls or plates with bark inclusions that any of you may have made and photographed. Frankly, this inclusion doesn't look much different from a linear feature that someone might have added purposely by segmentation (except it's right down the middle, which would be bad design). I'm not sure how deep it goes, but it will probably end up being only in the side wall(s) of a bowl form; or, I could purposefully use it as a design feature in a shallow plate or wide-brimmed bowl. It'll probably end up being about 7" - 8" in diameter. The question is: Do you think it's worth the effort to make an "interesting" piece out of this, or is it just going to look like crap?
2) If the artistic decision is to go ahead, what are the technical challenges? Should I just pretend it's not there and cut away, or should I be concerned about it flying apart? Should I harden it with CA repeatedly as I go down, or ...??? You tell me. What are the concerns and constraints?
Thanks for your comments, Gary
Re: bark inclusion
Re: bark inclusion
Walter Ahlgrim
>Be very careful as your blank could easily split at the bark inclusion.
I had one that seem solid enough mounted it on the lathe and began to ruff out a bowl. Suddenly 15 pounds of wood is flying around the room. Thank goodness it missed me had it stay on the lathe another 180 degrees I doubt I would be writing this. I had turned away the wood that was holding the branches together, leaving only the inclusion to connect 2 haves of my blank. I now view inclusions as void as they add little or no strength to the blank.
Re: bark inclusion
Re: bark inclusion
GaryG in MD
>Thanks for the heads up, Walter. If I do it, I'll watch carefully to make sure I have some good wood holding the thing together. ...Gary
Re: bark inclusion
Go for it!
Rick Davenport
>Go for it Gary - with caution.
I LIKE bark inclusions.
The potential for a spectacular piece is well worth the extra time and planning.
I'm looking forward to seeing the finished piece.
Rick
Re: bark inclusion
Re: Go for it!
GaryG in MD
>Thanks Rick. I'll be interested to see what it looks like -- if I can keep it in one piece. ...Gary
Re: bark inclusion
Re: bark inclusion
Bill Hale / Woodspinner
>Been there done that, sure got my atention. Sounded like a 30 06 when it came appart and went flying. Took down a light fixture , put glass all over the shop, punched holes in the wall and ceiling and scared the #$%^ out of me. I was not hit but learned when I am working on rough out of a crotch I slow down the speed. It may look good on the outside but the bark may goe further than you think.
Good turning and be safe.
Bill in Casa Grande, AZ.
