Re: Lacer hone - good value?
Greg H. from Wisconsin
>I'm fortunate, I live 1 hour from Alan. I have been to his shop and house for classes, PRICELESS. Incredible.
A few notes. Honestly. If you are using a fine or 600 diamond hone like the ones from Craft Supplies $26, and not getting your skew sharp, Alan's won't change that. The difference with Alan's, BOTH flats are coated, the others aren't, you do have to round profiles for gouges, etc. Those are made and coated somewhere in IL. I believe, for Alan. The coating is better than the others. My opinion, if you can afford one, YES its worth it. You have two flats, ($26 times 2, 52, plus the profiles that aren't on anything else, say 15 dollars worth, a better coating. It's really not badly priced, it ain't cheap, but it does have value. I have both, the cheap and Alan's. I like his better.
But as far as your skew, either should sharpen it. A few things to consider, Facets-if you have multiple or even two facets on the grind you'll sharpen the back and the facet only, not the edge. If you have one facet, check for glint, the reflection of light on the dulled edge, if you have alot, grind lightly, a little, hone it. Also the grind should be 1 and a half times the thickness of the steel, fatter skews longer grinds, etc. That will help getting the "base" for the hone established.
Think of it in Alan's Words.
"Sharpen a tool like you sand, 80 grit wheel, 600 grit hone, 2000 grit (white diamond compound) for power honing. (easiest way a work arbor on the lathe with the same diameter MDF wheel as your grinder, white diamond compound charged on the mdf after its trued, yada yada. RUNNING IN BACKWARDS, BACKWARDS. if you don't have that on your lathe, stand on the opposite side of the lathe, place the skew on it like a grinder and watch for black "mud" coming over the edge. Similar to sparks for grinding, you see it, your there. That polishes it, mirrored finish.) If you don't do the rough grits enough, the finer grits won't work. Also power honin isn't a everytime task, if the wood is being touchy, I will power hone. 9 times out of 10, the diamond hone in 600 grit or fine, same thing, is enough. But the skew can be sharpened past that even.
Any questions at all, email me. The skew is probably my fav. tool. I have three, one is one of the Glaser/Lacer's that Alan turns the handles for. It a blast when its right, and sucks when its not. Anything that I can do to help, let me know. Alan explains all of this in the free AAW member DVD this year and in the First skew video the best, Sweet side-etc. Well worth the money, both DVD's are!
Greg
