THE WOODRAT IS BACK!
Lacer Skew radius edge
Michael Stadulis, in Gloucester County, NJ
>Hi everyone,
Can anyone give me the details of how to jig a sharpening setup for the radiused edge on a Lacer style skew?
Thanks in advance,
Mike
Re: Lacer Skew radius edge
RK in Milw
>The only jig setup that I know of for a radiused skew is the skew jig for the Tormek Grinder. I am working on a simple way to make it so that Tormek Jigs can be used on a regular grinder. I will keep the group posted.
Ron Nelson
Flat platform rest...
Peter Teubel
>...from the Wolverine is all you need. Angle the platform up and get it as close to the wheel as possible. In my Delta grinder, I had to cut away some of the wheel guard for clearance. Lay the skew flat on the rest and adjust so the bevel matches the wheel. Then using your thumb to hold the blade secure on the rest about 1/2 inch below the edge of the platform, bring the tool in contact with the wheel and pivot it (the pivot point is the point where your thumb is). Repeat on the other side.
I originally purchased a skew jig from Veritas, but it was a pain setting it each time. It worked, but then I realized all its doing it providing a pivot point. Heck, my thumb can do THAT. I use it on all my skews (which are all radius...even the big 1 3/8 Lacer skew). Its really quite easy after a little practice.
>That's one of the reasons I don't use a radius skew. I have tried several grinds on a radius skew and I don't see any advantage to a having a radius edge. When I'm using the toe of the skew I can see the edge better when it's straight and the same is true with the heel especially when cutting beads. I've hear that having a radius edge is safer because it keeps the tip away from work so you don't have catches. That's not true you, you get a catch mostly because you are getting the cut above the center line of the skew edge. This allows the wood to apply too much leverage and rocks the skew deeper into the wood which eventually leads to a catch if you don't control it well enough. The tip is only a few centimeters further from the wood.
I also (and you too apparently) found it harder to grind the edge. Honing the edge was about the same for straight or curved but I found it difficult to control the grind. I grind my skews now mostly by hand even though I have the Oneway jig. I find I have more control. It's just like the Wolverine bowl grinding jig, it is a good aid but you can still screw up the grind if you don't control it properly.
Anyway that is obviously just my opinion but I do use the skew a lot and have played with all sorts of sharpening techniques and grinds.
To answer you question I found a simple jig that sits one the Oneway or Lee Valley tool flat tool rest works best for me for a straight grind. It's simply a piece of wood with a lip that rides on the stone side of the platform. This slides left and right across the stone. Then add 2 angled pieces to the top to guide the skew at the angle you prefer. Mine are set at 45 degrees.
Allen Neighbors
>John, for us more dense, can you post a pic of the jig mentioned in the above post? One with the skew mounted in it would be even better. Do you get a hollow grind on your skew? I do, and I would rather it was flat, and don't know how to grind it that way, consistently.
Thanks,
Allen
Monday, Monday... c'mon Monday!
I wish ...
Ron in Drums PA
>I wish you would have said this yesterday. :)
Last night, I tried to regrind one of my skews with a raduis edge. Maybe I need some more practice with it, so far I'm not too happy with the way it works.
BTW. I used a flat platform to shape the skew.
Re: Lacer Skew radius edge *LINK*
Bob Fawcett
>Here is a link to the Veritas jig.
Click on the instr. link and you can see how it is used. You could probably build a shop made jig that is similar.
Skew jig
skew jig photos
>Here are some photos of my jig. It works very much like the Lee valley jig except that there is a small ridge on the bottom that rides on the front of the tool rest to keep it straight. I have an Oval skew so I filed a radius in the jig to make the skew sit flat. I place the skew in the grooves and then slide it across the stone. Here is a photo of the jig.
skew jig bottom
skew jig in use
>Allen I like a hollow grind on my skew. I grind the skew until I almost have an edge. Then I use the E-Z lapp diamond hones from medium to super fine to hone the edge. Then I strop it until it will shave my arm. I like the hollow grind because it makes it easier and quicker to sharpen with the diamond hones. With a flat bevel you would have to remove a lot of metal to get the edge sharp. With a hollow gring you simply set the hones so they ride flat on the two raised edges of the hollow grind. This makes it easy to keep the hone flat and since your only removing little metal it makes it very quick to sharpen.
Allen Neighbors
>Again, WCers to the Rescue!! Thank you for the pics and the explanation, John. I have a hard time with a skew, and I blamed the hollow grind from my wheel. Well... it could have been. :o)
After reading Gary's posts on the Skew sharpening and use, I'm determined to give it another try. I've not sharpened it correctly, and surely haven't used it correctly. But maybe when I use your jig and my diamond hone, and follow his instructions on use... maybe I'll get somewhere.
I really appreciate the way you explain things... and the pictures are really good, too, helps a guy as hard headed as me to understand.
Thanks again.
Allen
Allen Neighbors
>Change "Gary's" in the above post to "Gregs". Color me red.
Allen
>Allen Many years ago I was learning to cut dovetails with hand chisels and just didn't have the fine control. The tool would slip out of the cut even though I thought I had it really sharp. I went back and sharpened the chisel with a perfectly flat bevel instead of hollow ground. Initially I thought it worked better but it took forever to resharpen. You had to hone that entire bevel. I went back to a hollow ground bevel and just concentrated on getting the tool sharper. That's what actually worked. My tool simply wasn't sharp enough. Just for those who might ask I did have the back of the tool really flat and polished to a mirror finish.
tek-Brunswick, Ohio
>I have that jig and it really worked well for me. I could get the same edge consistantly. You have to be consistant in your set up to do that, just like you do with your gouges. I would set the same extension of the skew out of the jig and set the platform the same distance from the wheel each time. Tilt the platform until the bevel rubs and you can repeat the grind time after time. I did a little experimenting though and found out I like a straight grind better. I just am just more comfortable with the straight edge and I seem to be able to see what it does easier.
Allen Neighbors
>What you say about the hollow grind makes sense to me, John. I've just never thought about it in that manner. I'm going to give it a try... I've heard too many good things about the skew, and watched Ruth Niles demonstrate what smooth cuts it will make (on Terry's Vicmarc), to not use it at all. I guess I've just got to get in a lot of practice. But I've got to get it ground right, first.
I've got all this information saved on my lap/desktop, to print out the next time I'm connected to my docking sta. I have a lot of things to do around the yard, before I can get into the shop and give it a go... my new lathe is supposed to arrive after lunch tomorrow, and if I don't do those jobs before lunch, they'll not get done! :o)
Thanks for your patience.
Allen
Brad Vietje
No Jig -- It's Done By Hand
Brad Vietje
>I was just with Alan Lacer a few weeks ago where he showed his unique grind and how it's sharpened.
First -- his preferred grind has a small straight-across area (not skewed), 1/3 the width of the skew, then a radius edge on the other 2/3. The straight-across part should be easy. He uses a flat tilted platform for both parts, pivoting the grind with his thumb, as Peter Teubel suggests.
He says the skew angle should be near 70 degrees included -- not the bevel angle, but how much the tool differs from a straight-across chisel. Same for his combination grind -- about 20 degrees from flat toe to radiused heel. He grinds on an 8" wheel, then power hones on a larger-diameter (9' - 10") MDF wheel with tripoli (wheel running AWAY from the edge).
For a simple radius, just pivot the tool while holding down in the appropriate spot with one thumb.
Safe spinning,
Brad Vietje
Newbury, VT
