hardening spalted maple
Paul Hammer
>Hi All,
I have been turning some great big leaf maple burl. The last piece i turned was a spherical vessel with spalting falling of the sides onto some great curl. This piece also has a blackwood collar. The problem i came into was when i it came to finishing. The spalted maple was VERY soft and the blackwood collar was hard. Is there a product out there that i can put on the maple after i turn the outside that will harden it, so i can turn the inside. I am also alcohol drying. I have tryed epoxy , but the to dont mix well.
Happy turning
Re: hardening spalted maple
Ric Taylor
Ric Taylor
>Paul,
Minwax makes a wood hardener that works well, slop it on and it penetrates soft wood. It's in a yellow can at Lowe's and Home Depot. Use it and store it with great caution, because it is VERY flamable. Don't allow any ignition source in the area.
You can also use thin super glue and thinned lacquer, both of which will penetrate the wood and stiffen the fibers.
Ric
